Supercharger project
- Thread starter Peter Empson
Peter Empson
Peter Empson
I've spoken to RPM today and it seems that I wasn't imagining it, the inlet pipe had to be 'convinced' to fit (with a hammer [
The good news is they're fitting the belt now and it shouldn't be too long before it can be fired up [
I am going to have to move the horns though, the air filter now wants to live there...
Gareth, I've not ruled anyhting out at this point to be honest, but as I had a whacking big IC with the kit I thought I'd start with it. As long as it doesn't block too much air to the radiator then it should be ok, but I'm sure time will tell.
Peter Empson
ORIGINAL: barks944
Great project btw, very interested to know about your results. What's the compression ratio of the S2 engine? I was wondering how much boost I could run on a lux engine with ~10:1.
I meant to check last night and forgot, but think it's 10,9:1 on an S2. It seems to be safest to run in the region of 5-7 psi, although I believe 9M have run considerably more (14psi) with the standard compression ratio [
Peter Empson
The good news is it's all done, I didn't speak to Ian who fitted it, but I doubt they'll have been able to test it at all as the map is probably rather rough, but hopefully it should be enough so I can get it home without too much messing around. I can then start work on it on Sunday as I still need to fit the MAP sensor and finish mounting the AFR guage as well as making a few changes to the wiring on the Innovate logging. Then the mapping begins [
Diver944
ORIGINAL: PSH
hey just noticed I got a mention by john in reference to Performance silicon hoses... oh and yes I do have them on my car too....
I have some PSH hoses on mine too, do you want them back?
That's great news about your car Peter E, I foresee a weekend of tinkering, blasting up the road, followed by more tinkering [8D]
Peter Empson
Only a few small issues so far, the piping hasn't been laid out quite the way I expected (don't know why, I didn't get a chance to speak to the mechanic) and I now need to make some changes before I'm completely happy with the layout, but I can't really complain as they got it to fit and I couldn't!
I am struggling to get it idling smoothly, which is a bit odd as i've always been able to fine tune this before when needed. For the time being I'll probably just raise the idle speed, except I can't find the setting in the Vitesse software (I even read the manual!), any hints would be gratefully appreciated. I certainly have a lot of learning to do with the piggyback in a rather short period!
Throttle response and low rpm behaviour is as before which is a big relief, so (touching wood) it's what I've been hoping might be possible, keeping the S2's low down torque/response with a seemingly linear gain as soon as the revs increase [
edh
Hope the current engine survives the boost! - keep emptying the catch tank [
Peter Empson
Mark, I'm hoping the high rpm whistle makes up for the noise at idle, it wheezes somewhat.
Peter Empson
ORIGINAL: Diver944
I can't remember seeing an idle setting in my Piggyback but I think it's still controlled by the usual 944 way of setting idle.
Lol! Well that would explain why I couldn't find it then [
Peter Empson
Not sure how many laps I'm going to be risking on Monday, I'm sure someone will start a sweep stake as to how many laps I'll manage with the pistons staying in one piece (preferably whilst staying inside the engine...)
Here's the obligatory pics, I'm going to have to change the IC inlet pipe at some point as it's not terribly elegant and I'm unsure why the IC outlet uses the original 968 pipe and not the S2 one I bought for the job.
![dsc01819ed.jpg](http://myweb.tiscali.co.uk/944lux/dsc01819ed.jpg)
![dsc01822ed.jpg](http://myweb.tiscali.co.uk/944lux/dsc01822ed.jpg)
![dsc01823ed.jpg](http://myweb.tiscali.co.uk/944lux/dsc01823ed.jpg)
