Suspension Upgrade
- Thread starter scratcn
ORIGINAL: mike220
Depends what model you have ? - they won't fit a turbo / S2. I researched all that when I was deciding what to go for.
Mike
? are you sure .
Neil Haughey
I have the koni inserts on my car and 944 M030 koni rear shocks, they work great but are really only for stock or mildly upgraded springs IMHO. I have 27 mm torsion bars in the rear and have the koni shocks set full hard now and the fronts something like 2/3rds hard. They seem to work better on the softer settings but at this level don't seem to do much if anything more then the stock F&S shocks I have on the 968 for example. Just MHO but I don't really see them as a serious track mod more a cheap way of replenishing the stock suspension with something that has a small amount of tuning/adjustment capability.
ORIGINAL: mike220
Mike
So what were you refering to Mike, Bilstein or Koni ?, changing the subject whilst checking my struts I noticed the springs have "PORSCHE 968 VA" printed on them in white paint, mean anything to anyone ?.
Thanks for that Neil. I have the later turbo, so trying to narrow down what inserts will fit is a task itself. Are these the same struts as a 968? What are the standard spring rates on a '90 turbo (200lbs)? I guess a reputable indie can advise, rather than those feeding the general performance market. I am sure Fen/Neil/BigDave can give a definitive answer. thanks againORIGINAL: Neil Haughey
AFAIK this was looked into before either on here or titanic and the Bilstein inserts are not designed for the S2, late turbo and 968 struts.
The Bilstein B6 inserts only fit lux's - I've done all the research and spoken to the helpful guys at Bilstein (when you can find out how to get in touch with them), and they WILL NOT fit a Turbo.
If anyone wants more detailed info, feel free to PM me, I didn't wanna ramble on too much, as it's been done to death on various threads in the last 6 months.
Mike
Neil Haughey
ORIGINAL: wibble
Funnily enough I looked this up the other night in the workshop manuals for both cars. Late model 944 turbo and 968 both listed as 28 N/mm and early turbos and S2 have 21.8 N/mm springs. Applying the handy converters found on the net this works out at 160 lb/inch for 968 and late turbo, 125 lb/inch early turbo and S2. TBH both sound low to me but if anyone cares to check the workshop manuals again and work it out please do (It was late and I was tired the numbers are from memory).
A couple of other things I remembered poking around the manuals and PET's; 968 CS springs and stock 968 springs have the same rate, the CS springs are just a little shorter so basically myth busted 968 CS suspension is more or less identical to stock 968. Both the 968 and the late turbo also have the same 25.5 mm rear torsion bars, S2 has thinner rear torsion bars the same spec as basic 944 (24 mm?).
ISTR that all the cars we are talking about; S2, 968 have different front struts even though they may seem the same. Likewise the rear shocks are different. ISTR that Bert Gear lists them as different with a different price.
Front wishbone castor blocks are not the same on 944 and 968 now, despite several years ago being told this by an OPC. The part numbers are uniquely different for 944, 944 M030 and 968. I have the 968 ones on my S2 which are a superb upgrade but just bought a pair for the 968 at 60 quid a pop now so getting pricey. Front strut top mounts are however the same part number on the PET for both 968/944 now. They are stupidly expensive though I was quoted something like £450 a pair the other day and a similar price for the rear suspension spring plates (again same part nos. across 944/968). So I guess its aftermarket for sorting out these 2 items.
The koni inserts are for all cars that had the non-rebuildable front Fichtel & Sachs struts, thus they are for S2/968 and late turbo's.
Neil Haughey
ORIGINAL: h4x0r7000
cheers mike.
one more question, the koni kits, would they be better than getting the suspension refurbished by promaxmotorsport?
Better is a personal preference thing really. I think they offer better damping than standard yes, though they're at the firm ish end of the scale for standard springs and torsion bars - perfectly fine though, I'm quite happy with mine, especially when you consider the price of other options.
Did you say you had MO30 suspension ? as it's only those ones that Promax can have rebuilt. Normal Turbo shocks like on mine are non-rebuildable, so it was replace or suffer with them.
Mike
When I researched this, I found that the struts that fit S2's, (later) Turbos and 968's are all the same, with the slightly smaller diameter springs. They all will take the Koni top-adjust insert, and fitting them is easy.
The struts for the earlier cars have unscrew-able tops, and you have a much wider choice of insert to put in there as they don't need bolting in at the bottom (as the cut-and-shut Koni ones do.)
I used the Koni inserts on my S2 and they made a great improvement. However, that could be more of a reflection of how past-it the old units were (and I was amazed at how well the 944 chassis hid the knackered-ness of the old ones!)
Chapest place to buy the inserts from was Proven Products. I've used them before, and their service is excellent and prices keen.
Diver944
ORIGINAL: 944 turbo cabrio
I am just wondering what will be the best compromise for my car which is driven in 5-7 track days a year but also must be used for nice day driving with the family and an occasional trip to Paris, Berlin or what/where ever.
For your useage I would recommend just the standard OE bushes. They will be a vast improvement over your worn out 20 year old pieces of rubber.
I would steer clear from the aftermarket bushes unless your car was more dedicated to the track and I fear they would make your Cabrio less than comfortable for normal road use
944 turbo cabrio
I found Design911 to be good on prices, although make sure they know the exact setup for your car when ordering bushes.
944 turbo cabrio
seems interesting.
I have also heard of Delrin being used by some companies but don't know if that is better than Polyflex.
Niels
