Transfer Box Issue
- Thread starter crossbro
Thunderbird2
Thanks if you can advise
Marksgd
I had a Macan diesel for just over two years it had done approx 16000 miles transfer box went on mine. Luckily it was still under warranty so free!!however i think you will be looking at around the £2000.00 for a replacement if not a touch more maybe. Im sure if you rang Dealership they would give you an estimate.
abhishek
Ziggycol said:Another transfer box casualty. My 2017 Cayenne S Diesel is currently getting a replacement under warranty. Just 3 years old and only 23k miles. Does anyone know if it's just a straightforward replacement with same or is there an improved item that solves the problem so it doesn't recur.
Terminator
When I drained the old fluid out of mine at 79,000 miles after experiencing juddering from the transfer box, it was a thin in consistency and almost black in colour proving that it had degraded either through wear, moisture ingress or a combination of the two. When replacing the drain and fill plugs you must be very careful not to overtighten these as the transfer case is alloy and will crack if you overtighten! You will need a torque wrench and tighten to no more than 15ft /lb or 20Nm (don't get these the wrong way around)! Once you have replaced the fluid it is advisable to get the transfer case wear indicator reset (a Porsche Independent Specialist which has PIWIS will be able to do this for you).
If your car has air suspension put it in the highest setting and you should be able to crawl under without having to jack up the vehicle.
My Cayenne has now done nearly 20,000 miles since the transfer fluid change with no slipping or juddering from the transfer box.
I would suggest trying this possible fix first, before going to the considerable expense of a new transfer box.
christopherryan
scaramanga
so many cases, clearly a case of a defect ?
tigertrout
So may be worth speaking to the main dealer if you have symptoms to see what they can do. I have had quite a few Porsche cars and love the brand but like all Manufactures they have problems but what annoys me is these car journalists saying being a Porsche its bulit proof which is not the case.
Marksgd
Mark
christopherryan
christopherryan
gtipirelli
car is booked in for diagnosis on 1st June as the local OPC are fully booked up. It’s a real pain as our second car is a 2 seater and the 4 of us are going to Scotland next weekend for a weeks hols. Hire car it is then
the car is now 4.5 years old with 37k miles and we have owned it since new.
Will keep you posted
gtipirelli
No signs of Transfer Box issues yet but wondering how long Porsche will extend the warranty on this common issue and failure?? Clearly I don’t cover that many miles so may not manifest the fault for some years......
Chris
