Well, the water softener is still in its multiple boxes.
Clutch fork bearings and voltage regulator turned up at 1pm, so back under the car. All the front end under car is done , including a new slave cylinder, I bled it from the bottom using a syringe I use for my MTB brakes. Seemed to work well. The old fluid was horrific. Clutch feels lovely.
Had a near disaster with the captive crossover bolt. Access from above using an extension bar, the socket needed to be pushed on from underneath. Fine until I went to remove it. The pin that releases the extension bar had fallen out , I contemplated leaving the bar in as there was no way I was pulling the turbo at this stage. I managed to get a screwdriver in to release the bar at the centre pin in the end.
Now drinking beer.
Top of engine bits and bobs tomorrow and back end if I get time.
