Turbo clutch
- Thread starter James0
I've packed and addressed the bits for you guys. Work depending they should get posted this week.
I found the original manual for the radio too, it's a bit battle scarred but you can always bin it.
Dan944t
blade7 said:Plumbed in water softeners aren't used where I live now, but my neighbour used to connect something similar to his outside tap for washing his car. He reckoned he just rinsed the suds off and no water marks were left?
I could do with one of these then!
944 man
James0 said:The softener cost more than the clutch and bits... Should save me buying a new shower every 5 mins though.
Thanks James. My F35 hasnt been used since 1992 - Im really looking forward to getting my favourite Nirvana tape back out of it!
James0 said:Tip for the dipstick tube to inlet manifold, ratchet spanner with a bit of nitrile glove to hold the bolt in place. Use a screwdriver to apply pressure to the back of the bolt as it tightens.
Too late now, but an even bigger tip . . . make two cuts from the dipstick tube hole straight down to create a slot, put the bolt in finger tight, slot the dipstick tube into place, fasten up bolt. Takes seconds.
blade7
Well-known member
Parts received, thanks. I owe you a beer James.
blade7
Well-known member
James0 said:No prob, I sent the whole unit as its no use to me. I think it has an Alice cooper tape in it.
I always liked her.
