scam75
Well-known member
Well she goes again! Ended up being the Bosch HFM-5 MAF unit that was goosed, thankfully I had a spare brand new one. It has either gone of its own free will or else it was tipped over the edge by the suspect wiring to it. We will never know!
Anyway, after waiting a week for Royal Fail to lose my new plug which should have been 24 hour delivery, I ventured to the scrappy today, how that brought back memories! I needed a 5 pin Bosch MAF plug so found a Golf and removed one. Slightly different looking, but 5 pins, and Bosch, of course it will fit! It didn't. So I then set about making it fit, and changing all the wires over, so I know I have 2 good ends on that harness now. Fired it up, same, starts and dies, also battery starting to go flat and Mrs about to leave for an overnight with the kids in her car with her ready 12v supply for jump starting. Asked her to wait 5 mins as I dug out the new MAF and did an F1 style change over, fired it up with all the hose clamps still loose and wires all over the place, and off she went! Joy! Then off she went, with the kids, and while it was still running I got all the wires in order, done up all the hose clips and refitted the snorkel.
Good old test drive and can report all beans are present. I have a slightly better idle AFR of 14.5 (low 14's before MAF swap) and WOT AFR of low 12's. This is the first time since the rebuild I've buried the throttle and kept it there, 4th gear, just under 20psi boost falling to 18psi as you do with an MBC, many leptons showing on the speedometer on my private road. No bangs or noises or fluids lost and all perfectly clear out the back of the tailpipe. Got to be happy with that. I'll probably change over that plug for the proper one when it finally arrives, but for now it should be fine and all the wiring is good.
Possibly the new MAF, or the wires now not being ropy, have led to the better idle AFR, who knows, but all is as it should be now! Time for beer!
Stuart
Stuart
