Dan944t
scam75 said:Ha ha, nearly!
Some more progress. Turbo water pump done and water system is now pressure tested and leak free. Front end all built up (and tidied up) and moved onto replacing starter motor. The 1.7KW one is about an inch longer and the heat shield no longer fits! (It bolts onto the starter ok at terminal end but is an inch short at the bellhousing end) Is there a longer version of the heat shield available? Not a huge drama if not, can do something to secure it. Also the solenoid seems to have been bolted on incorrectly oriented, meaning main wires not reaching/routed incorrect. Possibly a result of the rebuild process. Had a quick chat with Martin (Waylander) on the phone there and he kept me right on some electrical stuff, many thanks Martin! In the end we unbolted the solenoid and re-oriented it as the main wires were not reaching any of the two big terminals. As ever we ran out of time and tomorrow we will have to slightly widen the ring connector on the small terminal to fit over the post, and then we should be ready for another start-up!
Stuart
how exciting Stuart!!
nearly there mate
