blade7 said:
An engine builder told me the oil that's flung off the crank lubricates the cylinder walls and helps cool the undersides of the pistons....
With all due respect, I don't think your engine builder understands the principles of crank scraper/windage systems, they actually reduce both engine and oil pan temperatures as proved on a dyno. Engine power is increased especially mid/top range and the engine has a much freer revving feel to it. My own engine was transformed, now it's difficult to say what made the biggest difference as let's face it just about everything was upgraded but I'm sure that the way it responds to the throttle is in part due to the crank scraper, makes the engine feel like it has a much larger capacity. BTW Ishihara-Johnson have continued with their development on the 944 engines and now have a very impressive windage system, if my sump gasket ever fails in the future I'll most certainly look at installing this latest development.
You'd be surprised at how many OEM crank scraper/windage systems are out there in every day cars and this is nothing new, for example the RR Merlin engine as fitted to the famous spitfire employed such a device.
Here's a little more info from the Ishihara-Johnson website, there is more there for anyone interested...
Quote:
What are some of the benefits?![. [FONT=verdana,geneva"] [FONT=verdana,geneva"]](/forum/styles/default/pcgb/space.gif)
Less rotating mass for the engine to accelerate because of the removed oil
Less loss of power because of excessive drag caused by oil droplets in the windage cloud
· Helps reduce engine damaging oil-foaming both on the surface and bubbles deeper within the oil
Helps avoid oil starvation by keeping the oil in the pan during hard braking and turning as well as during off-road driving
Helps to cool critical engine parts by quickly returning heated oil to the sump
Helps to prevent the cylinder walls from being overloaded with oil
Can help with fuel efficiency
During normal engine operation a significant amount of oil adheres to the rotating assembly or becomes entrained in a "windage" cloud surrounding it. It should be remembered that the particular characteristics of oil adhesion and/or oil-in-air entrainment vary depending on the engine rpm and what the vehicle is doing at the time. How the oil droplets are kept and drawn into the tornadic windage cloud is explained by the phenomenon known as the
Tea Leaf Paradox, which was first described by Albert Einstein in 1926. It is counterintuitive that oil droplets would be kept and drawn into ("entrained") rather than completely expelled out of the windage cloud due to centrifugal force.
When a portion of the total droplets are small enough in physical size the predominate influence on their behavior switches. Rather than just their momentum due to being ejected from or impacted by the rotating assembly they are guided by the air currents in the windage cloud.* This droplet behavior in a gas atmosphere, which is a type of "fluid", in the confined volume of the crankcase is what the Tea Leaf Paradox addresses. The oil droplets have a greater density than the gas molecules.
Remember that an "equilibrium" of entrained oil is reached for the particular operating conditions. This means that not all the oil is held but rather that the amount rises until a certain point is reached and then the extra is not taken in or it swaps places with oil already in the cloud that is then released. Generally the higher the rpm, the more oil that is held because of the higher pressure differential. It is not unusual for a quart or more of oil to be suspended in the cloud at high rpms in many engines.
end quote:
regards
Pete
