What can cause rich idling?
- Thread starter scam75
scam75
Well-known member
Argh
Stuart
scam75
Well-known member
I think I will get a probe up the exhaust to check CO at idle in case my lambda sensor is at fault. It's about 2 years old and fitted in the factory bung. I have heard stories of them not lasting too long in that location. Does anyone know if the lambda sensor can be cleaned? It does however sit at stoic (14.7) with the engine off after self calibration.
Still puzzled.
Stuart
scam75
Well-known member
ORIGINAL: robwright
Do you still have chips to go back to afm just for testing Stu? Obviously assuming you still have the AFM?
That would have been sensible however my AFM disappeared in Al's garage never to be seen again! And I never had standard chips, my car had a superchips chip in the DME when I got it!
HOWEVER! The problem is solved. And popping a barn door back on would have solved the issue. It was MAF related but not the sensor itself, they always fail lean, it was in the little control box that sends the signal back to the ECU. The genius that is Jon Mitchell pointed me towards it after kindly analysing some data he requested when we spoke earlier. CO, HC, various AFR's etc. Turns out one of the potentiometers was stuck in the control box. A zero cost repair and fuel bills set to tumble dramatically! Delighted doesn't sum it up. I thought the old bank account was about to be hit with a vitesse maf type hole in it as I didn't really fancy regressing back to barn door technology!
A delighted Stuart
Hairyarse
ORIGINAL: robwright
It dif fail on a manky sill and a bald tyre though. At least I was expecting those. Whoops the new tyre turned into a full D90 refurb though.
Pics needed [
scam75
Well-known member
ORIGINAL: TTM
Good to hear!
What model of SciVision MAF do you have, is it the older one with the gold rectangular control box or the later one with a cylindrical control box?
It's a mark 2. Has a 951 part number and a silver rectangular control box.
I would quite like to source another control box off a trashed one somewhere to have a play with and have spare.
Stuart
scam75
Well-known member
ORIGINAL: Frenchy
Well done Stu and JMG !....................All good learning for us, get the oil changed, as when i was having starting problems i did not always pull the DME and the oil was being flushed with petrol, when i dropped the oil you could smell fuel in it................Alasdair's advice BTW.
My thoughts exactly Jim. Oil n plug change this week!
Stuart
