What can cause rich idling?
- Thread starter scam75
scam75
Well-known member
ORIGINAL: lacedr
good find.
oh bloody hell mine at 10, i had better start checking thing!
Well you're either getting 6 mpg or your wideband is stuffed! Either way check asap!
Stuart
lacedr
From cold the car has to be kept reving for a while before it will tickover, it has been like that since I purchased the car the op told me it only just started to do it.
The car has emerald ecu a map and a maf.
Any ideas what it could be ?
scam75
Well-known member
Stuart
ChasR
Lacedr, you do know that the Emerald software is available for free, and thus can adjust certain parameters that way? For me, it aided in ruling out certain issues on another Emerald ECU'd car (in that case, it was as simple as a poor connection). Did you get the Emerald cable (a USB to Serial item) to work with it? Another generic cable will not work (and may cause damage) due to the pins on the Emerald items being switched about.
lacedr
The car is not on the road at the moment,so unable to take anywhere.
chas,
I do have the software and lead but do not want to play too much with it as I do not really know too much about it.
I have a standard map set up from emerald and one that came with the car.
Update: I think I may have found the fault,the wire that goes to the temperature send was a bit bare, now repaired got to start the car up and see fingers crossed.
Dave
scam75
Well-known member
Update on my own car, had been getting about 75 miles to 30 quid of petrol before my fault was cured, I have just got 100 miles there from 30 quid. All still good with AFR's and clearly my car was very rich throughout the rev range whereas I was seemingly just chasing an idle fault to begin with. I am learning more about AFR's all the time and I can say without hesitation that an AFR gauge is your best friend on a turbo car with even a hint of mods and altered boost from stock! Quite fancy one superimposed on the windscreen though as I spend more time looking at my boost/afr gauges in my cubby hole beneath stereo than I do on the road lol!
Stuart
