windscreen replacement
- Thread starter Guest
The noise is caused by this outer trim moving on the car body and/or the glass when under way.Apparently the teflon tape referred to in other entries on this subject is £70 per roll.
The screen does not appear to leak (fingers crossed) and I have cured the creaking by lifting up the outer rubber trim and applying a smear of Holts rubber lubricant right the way around the inside of the trim, top and bottom.
Don't know how long the effect will last.TC
Gordon Attar
The guy that came out was well experienced had done a lot of Porsches even to the extent that he new how to take out the speedo(964) to plug in the ariel etc.
psand watch them do the job for your own piece of mind
ORIGINAL: clyde
Chances are they sub-contracted it Sundeep. I had mine done as part of body warranty work and all glasswork was done by a windscreen specialist. It took three re-visits to get it right but the final job is excellent.
I had mine done at the same time as a body work warranty claim
and they did subcontract and I wasn't expecting them to get it right 1st time [&:]
but at a mere 2 attempts it was at the right place to fix the errors [:-]
kbooker
clyde
It did all turn out well in the end but not before I spoke to the owner of the body shop who subsequently leant rather heavily on the manager of the screen specialist.
russellbarnes
sbloxxy
Pickled Piper
ORIGINAL: pse_SC
I'm thinking of getting my done, but it concerns me as well about all the stories people have. My question is: Why should it take more than once to do a proper job? Surely if they know what they're doing they should get it right straight away?
The very high skill level, personal attributes and experience required to get a job as a windscreen fitter coupled with the high wages that they pay ensures they are in constant competition with kwik fit and McDonalds to attract and retain staff. This is the major contributor to their ability to get it "right first time". My appologies if I have done McDonalds a dis service.
pp
I had my windscreen replaced 4 years ago. It was creaking and so I asked the independent to apply the approved Porsche tape fix. They said at the time that it was a bit of a job since someone had previously applied mastic/silicon which made their job harder (in fact they ended up cracking the screen but kindly replaced it at their cost) and which obviously didn't stop the creaking. Unfortunately after having replaced the windscreen they didn't apply the tape fix as well so the screen has started to creak again. Bit of a digression but basically applying mastic doesn't stop the creaking. I believe that the tape just stops the windscreen rubber "rubbing", which is the creaking that you hear
Hope this helps
Pickled Piper
pp
timandrews
I am very interested to hear how you get on. I also have a c2s '98 model that is kept in S of France and need to look fairly soon at windscreen replacement. We are 30 mins west of St Tropez.
I am not very keen on Porsche at Frejus or Toulon and have had mine serviced at Moujins Autosport at the recommendation of Flat 6 editor.
johnedwards
I now understand the need for the tape. In the manual it actually shows the gap between the screen surround and the body filled with mastic. I have to say that it is difficult to understand how the tape is better than a mastic fill but if Porsche say so...
In fact mine has nothing between the screen surround and the bodywork and creaks like a good un. I have tried the chain lubricant but it did not make any difference. I understand it has proved good for some so perhaps I didn't put it in correctly. Anyway I need a new screen as it has several chips and an excellent sandblasted finish.
I am in discussions with my local body shop at the moment. I need some paintwork, the inevitable rust around both screens, so am going to use a local shop as the work they have done previously on my Merc was very good. They have a modern shop with all the latest gear and computerised paint matching and if I go to the OPC at Puget they will only sub the paintwork.
Thanks Pickled Piper I will replace the rubber surround and the moulded cover as well.
I will post my experiences after the work has been carried out.
Thanks again to all who posted.
John.
cobalt911
I went through the same thing. Autoglass also said the same thing. However, the interesting thing about this is that they are the same manufacturer but 'slightly' different. I had a creaking screen after autoglass replaced mine (and they did put in the teflon tape), they had another go - same problem.
I needed to have some minor corrosion looked after at specialised in Reading and Karl noticed that the screen was 'slightly small'. When we looked over it it did indeed appear to be a mil or two out (tiny amount) but enough to not fit quite correctly and give some noise.
In the end, after the 2 attempts, autoglass agreed to fit a Porsche screen and immediately the difference was apparent. The tinting at the top was better, and it fits perfectly....touch wood no noises since. Hard to describe, but the difference between the two was a small 'p' in with the manufacturer logo but when I compare the size and apparent quality it is clear why porsche-supplied was more expensive...
sorry - this may not help much!
On another note - I found autoglass in Reading to be a world apart from autoglass in Bracknell, if you happen to be in this neck of the woods! Want glue all over the place? Then go to Bracknell!!
Mark
