James,
That is extremely helpful - thank you very much. (I should also add that if you can take pictures like that first one, you should consider a career in Modern Art. Had I not known was it was, I could have sat for hours looking at it, admiring the shades of black and the different reflective surfaces and not had the faintest notion what I was looking at!)
Interesting that your two windscreen rubbers are cut differently. Yes, the passenger side one does look neater. Maybe I need to find some side cutters and trim mine at both ends. It does seem a slightly odd design; I guess the idea is that the windscreen is held in with the mastic, but the rubber is necessary to fill the gap between edge of the glass and the metalwork. At the bottom, there is no such gap to fill, so the rubber just needs to end, somehow.
Thanks also for the comparison shot of the BMW. And for the picture of the aeriel cover. I think you're right - it's just badly fitted. Which is a bit odd, given the care the fitter took with the rest of the job. I'll take a screwdriver to it today. And tighten those blocks up. And move the drivers-side A-pillar interior trim down by about 3mm (he re-fitted it a bit high, and there is an unsightly gap at the bottom of it now.)
BTW, recommending names is a great idea, thanks Colin. Mine was done by Mark Carress of Auto Windscreens. If anyone else has their windscreen repaired by them, I'd recommend asking for him by name. Very glad that yours went well ... I have yet to test mine in the wet (I don't have a hose!)
