924Srr27l
Strut Top ,
I've cut out a section from a breaker so that I can look at designing a Rubber Top mount
that will locate the Shock absorber piston rod 25mm higher and hence allow more movement
specifically for lowered cars.
Ground Control USA make such a mount but it's used with a Spherical bearing, and this would offer
no vibration absorption like the OE rubber Donut style does from the 924 & Early 944's
The underneath had the Underseal which I ground off and you can see the bronzy Zinc Galvanised Steel
and the Spot welding marks
I want a plate similar to this Golf one (below) but with more depth to house the Rubber mount higher.
Possibly a spacer to keep the Spring pan the same as OE, or the 2.5ID spring will fit through the
4" chassis hole if required.
I'm also hoping to get some quotes on Stainless Steel Strut tubes, threaded for Adjustable platforms
and the same design as the early 944's so any Insert can be fitted (Sach's , KYB, Koni, Bilstein, Spax etc..)
Early Stub axle sizes, although I may consider a Threaded bottom bracket and then the later type could also
be made if I consider making & selling them.
R
R
