944 Dyno Day Saturday 20th May 2006
- Thread starter Diver944
carlmthompson
I have to be away by 11ish, so am hoping to meet alot of you before I leave!
PS - anyone know what the postcode is? - helpfully the website doesn't tell you!!
Just had a thought - I sold my BMW the other day, and raided the Porsche to nick the radio. Guess I have to hastily install a radio tomorrow - my pops is coming with me as company, but 7 hours is a long time without any news!!!
This round of mods were fitting a copy of Rick's CDI system (which sees the introduction of motorbike parts in the mix), removal of the idle control valve (so nobody can take the mick that the little K&N has fallen off again), replacement of the failed wideband sensor, removal of the fuel damper, removal (on probation for now) of the vacuum pipe to the FPR and finally the addition of a fairly large oil cooler with in-line thermostat and an oil temperature sender.
I also found the KLR boost line that I had been using to feed my map sensor had a crack in it, which I am suspicious was the cause of my jet engine sound as well as doing my boost control no favours.
Idle when warm is now rock solid with the payoff that when cold it's non existant. Off-boost the car is creamy smooth compared to before (even though the fuelling is rich across the range for now), which I guess is the result of a super-fat and longer duration spark.
All in all a good week's tinkering.
My car ran for the first time last night with a vitesse MAF kit - (MAF / Cone filter / 3" J Pipe / piggyback board that replaces the chip)
Started first time to a rock solid idle was smooth through the range - dont know if its quicker as the rain meant lots of wheelspin. It certainly sounds a lot different - the turbo has developed a voice! Hope to get a few more miles on it later today - and to neaten up the power supply.
Tony
Diver944
Personally, I am going to keep suspiciously quiet at this point [
Carl I don't know what the Weltmeister postcode is but I presume you are coming down the M1 and will exit at Junction 15A. There are big brown signs for Silverstone from that point onwards
hartge bob
NN12 8TN should get you there
Edited to add;
Damn, too slow [
carlmthompson
See you all there!
Anyway, can I be the last official cancellation? I'll still be there as will my car, but it won't be on the rollers. I'll explain tomorrow, but for now let's just say "bang, rattle, smoke, pool of oil."
Diver944
I only wish my car had been one of them [
