RS2000CUSTOM
ORIGINAL: robdimond
Fantastic, thanks for the write up!
I assume you did the brake lines without dropping the rear beam or transmission? Mine are a bit iffy so I might do them before the next MOT if it's simple...
Rob
Certainly did leave rear beam in place
One tip though regards the brake pipe T piece
fit the 3 pipes into the T piece BEFORE bolting the T piece back onto the body
this way you can manipulate all the pipes easier into position and tighten pipes correctly
