944 GBC - My 1992 944 S2 3.0 - The story so far !
- Thread starter RS2000CUSTOM
RS2000CUSTOM
ORIGINAL: Jase1969
Great thread and a stunning car.
Thanks Jase
Couple of new additions (steering wheel already fitted)
and I will doing a modification to the later "crimped" 944 S2 front struts to be able to use the Bilstein inserts
Interesting, can you tell us more about this modification?ORIGINAL: RS2000CUSTOM
RS2000CUSTOM
ORIGINAL: PAUL RUDDY
I'll have the billies and steering wheel when you sell it Dave [][
I will should be able to offer front struts on an exchange basis for late S2 struts if my idea works
ORIGINAL: zcacogp
Oli
Once I finished then I will let you know
as above though - if my idea works then I will may be able to offer exchange on front struts
RS2000CUSTOM
Today I have fitted a Digital Clock repair screen
About and hour and job done !
btw:- clock was fine last year it "clouded" during the winter months
RS2000CUSTOM
RS2000CUSTOM
Removed the old original units and whilst they had OK compression they had very poor rebound
Bilsteins have excellent compression and fast smooth rebound
Just need to finish off tomorrow and fit lower mount bolt
Then move onto sorting out a method of fitting the front inserts to the "crimped" S2 struts
RS2000CUSTOM
ORIGINAL: Waylander
Those fuel lines look a little crusty?
The lines have slight surface corrosion and the ferules are still solid - no deterioration over the last year
ORIGINAL: 944Scott
Are they John Guest fittings on those fuel lines?
Not sure as previous owner had the lines replaced (rather large repair invoice in history file)
RS2000CUSTOM
ORIGINAL: Waylander
That does look like a push fit connector on the return line?
They are push connectors but not sure who John Guest is ?
RS2000CUSTOM
RS2000CUSTOM
Rear pads removed, calipers cleaned and park brake adjusted
All good
Front brake calipers cleaned and new shims fitted
Just need to sort out the front struts now and all ready for Dinslaken 2015 in Apr/May
RS2000CUSTOM
ORIGINAL: 944Scott
Keep an eye on those push fittings as that's not what they are intended for. If they pipes get removed a few times the grips inside the fitting end up scoring the pipework and they end up weeping.
ORIGINAL: Waylander
And possibly not even legal to use
Bet your glad the mot man has not spotted it
Thank you for your concerns and here is the Inspection and Fail Criteria for MOT's regarding the fuel system
http://www.motinfo.gov.uk/htdocs/m4s07000201.htm
The connectors were fitted in 2006 by Bob Rose and a further leak elsewhere was rectified by Tom Ferguson in 2010
So nearly 10 years have passed since the connectors were fitted so that isnt too bad and 10 MOT's later they are still there LEAK FREE !
