944 Turbo S Engine Rebuild Thread
- Thread starter Eldavo
scam75
Well-known member
Stuart
blade7
Well-known member
Should the intercooler get heat soaked on track then there is a table in VEMS that reduces boost based upon inlet temps going over a set threshold, also pulls injector timing based upon coolant temps too.
blade7 said:I was replying to Stuarts post. I'd like to fit the VEMS to my car though.
Do it - it’s pretty straightforward and I’m happy to talk you through any issues that come up.
scam75
Well-known member
Thanks Blade. With the MBC it peaks about 19psi in 3rd, 20 psi in 4th and 21psi in 5th, and drops off 2 or 3psi holding throttle. So it's in the sweet spot in 3rd but maybe a tad over in 4th/5th. I suppose an EBC is the answer but in all honesty the car sees very little WOT and I don't want to lose the 2 or 3 psi through 3rd just to make 5th peak at 18psi. Saying that, it probably won't make a massive difference and now the engine is rebuilt I'm sure it will be more efficient across the range so will probably dial it back a tad in the interests of longevity!
Out of interest I spoke to Lindsay a few years ago and they were confident that their chipset will fuel properly for 23/24psi using super unleaded. I suppose it's more the unnecessary load on the turbo and piston rings etc. that I need to consider.
Stuart
blade7
Well-known member
scam75
Well-known member
blade7 said:I'm guessing you're running at least 55lb injectors at that boost level? And Lindsey do make some pretty bold claims about some of their products. Flirting with high boost for a second through the gears, isn't the same as holding it in top gear IMO. Depends what the roads/enforcement are like where you live I suppose.
No, I'm on cleaned standard injectors and the fueling is all good, low 11's AFR at peak boost (21 psi). I had 55lbs injectors for a bit and the car never ran right with my chipset despite there being a toggle for 55lbs injector mode. Chucked the originals back in and all good for my needs. I won't be looking for any more boost/power. I do have an uprated fuel pump though and a recently new fuel filter to help! The pump is a Sytec Motorsport one which is a Bosch 044 equivalent. (I know the injectors can only pump what they can pump but all seems fine)
Agree on manufacturer claims but happy enough my peak boost and held boost levels are well within safe parameters and I only run v-power in it which I think is 99 RON.
I think I'll eventually go down the EBC route and stick to a flat 18psi. Get the thing back on the road and run in first!!
Stuart
scam75
Well-known member
James0 said:If you're not in an area with lots of cameras the start of full boost in top gear, it won't be long before you are.
blade7
Well-known member
scam75 said:blade7 said:I'm guessing you're running at least 55lb injectors at that boost level? And Lindsey do make some pretty bold claims about some of their products. Flirting with high boost for a second through the gears, isn't the same as holding it in top gear IMO. Depends what the roads/enforcement are like where you live I suppose.
Stuart
18lbs on standard injectors and a 3 bar fpr is all I'd be comfortable with. 25 years ago I used to rag my chipped 87 Cosworth in top gear all the time. I'm not so brave now though. Whatever boost you run, you'll get used to it. You have to draw a line somewhere. Do you feel lucky [].
James0 said:That 16v engine looks awesome.
I wish I'd had the k27/8 in my 3L tinkered with. It's nowhere near as much fun at sensible speeds as the undersized K26/6.
I had a K27/8 rebuilt and upgraded by Turbo Dynamics - 360 degree thrust bearings and machined out for a bigger hot side billet wheel with clipped vanes. If it’s anything like the K26/8 they did for me then it’ll spool up early and hold the torque flat.
Turbo fitted on a nice aquablasted pedestal mount with an AN fitting for the AOS drain. With that in place I could get the crossover pipe bolted up. I had the flanges cut off a set of turbo exhaust manifolds and tacked onto the 16v exhaust manifolds in situ then welded up properly and all bolted up.
Had the oil filter console modified to take some AN10 fittings so my other oil lines will attach straight up too.
