944 Turbo S Engine Rebuild Thread
- Thread starter Eldavo
TTM said:Looking forward to hearing your impressions. It is always exciting to try a new turbo.
Thanks, I’ll try. Something like "stu-tu-tu-tu-tu-tu”
Dan944t
Eldavo said:
i tried to find it in WH Smith the other day and they disnt have any ….. i reckon you’ve bought them all
The turbo sits at a slightly different angle too so the crossover pipe needed a bit more work than just swapping the T3 flange onto it too. The downpipe is tight but is a true 3” ID with a V-band at either end and can (just) be removed with everything else bar the brake booster heatshield in situ too . . . not that I’m planning on going back in there again anytime soon!
Turned the fuel pressure up to 4 bar and tweaked the VEMS req_fuel settings - for once the theoretical calculation was actually the correct practical application - usually it’s close but still needs a tweak.
Also fitted a remote pressure gauge to the inlet oil feed of the turbo and zip tied it to the wiper - I wanted to see what oil pressure was under WOT to ascertain whether I needed a restrictor plate in there or not (Holsets are happier with higher pressure than BB-cartridge Garrets and the like). Voltmeter also decided to sit at 10 for no reason - despite the voltage when running being 14.4v according to VEMS - there’s always something isn’t there?
Weather was reasonable yesterday so got it fired up and out for a spin with plenty of logging and VE fuel table autotuning on the move too.
Now time to add some boost! I’d turned this down to about 12psi and didn’t use more than gentle throttle but even so it was still a decent kick in the back and some decent speeds and overtakes were accomplished. This turbo is much more efficient with the bigger hot side and the duty cycle numbers I was getting from the log files to update the boost table were considerably lower than the old ones. Less duty cycle to hit the same boost at the same rpms means better spool up and better efficiency.
Only issue I really had was one of the block-offs I’d put on the crossover pipe (new turbo is oil cooled only) was leaking and it took a bit of detective work with a torch and a mirror on a stick to find it - just a jubilee clip that needed nipping up thankfully.
Just need to wait for another dry and warmish day (in November) to get some more boost and fuel logs from higher up the rev/pressure range and then I can take it to the dyno with most of the hard work done.
Dan944t
Eldavo said:Car was very lumpy to drive and I could see that there was a lot of fuelling correction being done so did lots of transient load acceleration whilst keeping off boost and pulled over every 5-10 minutes to burn it to the ECU. After half an hour the fuel correction table went from the first picture to the second and the car drove really well.
looking good mate ????????
blade7
Well-known member
Good job. Did you consider some exhaust wrap on the downpipe, to protect the AOS. Seen a few pics of that on big turbo/downpipes.Eldavo said:Car went to the fabricators for a week and while it was there we decided that rather than modify the existing 2.75” downpipe for the new turbo (as it’s a 3” V-band outlet), they would make me a new downpipe.
Changing the subject, I have a big K&N cone filter 200mm long x 150mm dia wide. I was planning to cut off the headlamp bracket, and site it behind the headlamp. I'm guessing it will be too big to fit in the wheelarch?
blade7 said:I'm a bit surprised the fueling requirements changed, while the engine was off boost. Is that due to the exhaust flow through the new turbo/downpipe being less restrictive?
I’m not surprised, I omitted to mention that I turned the fuel pressure up from 3 bar to 4 so obviously it will need less when off boost. [
blade7
Well-known member
Eldavo said:Re: Air Filter I found out the K&N part number of the one that LR supplied in their MAF kit and bought that one. (I believe it is an RU-3130)
I managed to just about get it to fit in the wheelarch knowing that if it didn’t then it would fit behind the headlamp.
Had a quick google, and the K&N I've got is a fair bit bigger. It will only fit behind the headlight if fitted vertically. Still it has the right size inlet, and because the box was a bit damaged it was cheap. I'll drill a few holes in the plate underneath where it's going, and hopefully it wont get covered in crap.
