944 Turbo S Engine Rebuild Thread
- Thread starter Eldavo
I also opened up the box of parts I got from Nick Jackson of Nickson Motorsport, he had my down pipe and exhaust manifolds Cerakoted so due to the super tight clearance I fitted the down pipe and turbo now:
Thinking about it I really should’ve had my exhaust manifolds and crossover pipe converted to V-band before I had the manifolds Cerakoted - I’ll speak to my welder and see if it’s still possible. If the bottom of the exhaust manifold Cerakote ends up becoming sacrificial then I’m alright with that.
Also gave out nearly 100 Chupa Chups to Trick or Treaters after turning my hallway into a Halloween Themed Rave, I don’t waste my evenings:
Well, the hangover is on me - I thought the thick edge on the damper should point frontwards, and that is wrong, sorry. Not spending much time tinkering with these cars anymore is beginning to cause memory fade... :-(
I think even I’d struggle to get this on the wrong way around!
Ordered an Athena head gasket 2 weeks ago, just had an email back to say 5-7 days delivery actually means December now so I’d better measure up for a Cometic!
Kongsodoken
if you want to keep the shiny gold fixing gold I can recommend corrosion X
stops the the oxidation for about 2 years -
Got any 3" inlet bits I can use?
My inlet is all 3” - I use a 4” to 3” silicon reducer on the turbo inlet.
It’s a smidge thicker than I’d have ideally liked but as both deck and head have been skimmed it’s pretty much bang on for compression - just a tad more squish.
It’s a MLS fibre-backed gasket with a silicon bead and 4 cut-rings that bite into the head for boosty boosty applications:
Extra careful on the timing - 113mm bang on:
And then the final push left me deflated, apparently the QH QTB247 belt fits the 16v 944s and 968s but I can tell you now IT DOESN’T as it’s too short. Even taking the tensioner off it was miles out - another one to return and Justin Webb leaping to the rescue with overnight parts from Sheffield en route as I type this!
Timed everything up and turned it round many many times:
Still some things to tighten up but can’t do those until the flywheel and subsequent flywheel lock are in place. Next stop is the rest of the top end.
