spyderwhite
that front end is just not doing it for me it looks a mess!goes with the horrible looking rear end of the 981 which I never have got to like.
ORIGINAL: flat6
In those bitterly cold looking weather conditions FBR, you might actually get more grip with the suspension set softer, allowing the tyres to bite a bit more independently from the body's movement fighting against them. But maybe the new PASM has that covered too[]
ORIGINAL: flat6
With regards to grip and stiffness, I meant that the stiffer the car (chassis, suspension or whatever) when conditions are low grip, the wheels can more easily lose contact with the road as everything more moves together and a tyre can become unloaded. On a softer setting, the greater suspension travel allows the wheels to stay in contact with the road easier. You give away some 'roll' but the tyres are less likely to become unloaded (you see a slow-mo in Harris' video where he unloaded the front right tyre until it is clear of the ground but in the dry, the 3 remaining tyres have enough grip. In the wet, you'd rather keep all 4 tyres in contact with the road). So the fact that the 981 chassis is very stiff adds to what I was saying. However, in reality, as you have tried it and the car copes with it no problem, no doubt actively adjusting the damping so that there is no problem. I think 987 PASM would of course react, hence the name 'active', but nature of its Sport damping setting would more likely get you into trouble in the first place in the wet.
In dry, high grip conditions, yes, the stiffer the better to transfer maximum load to the whichever tyre has the grip and you're less concerned about an unloaded tyre as the remaining tyres have enough grip to cope.
Do you have the 2.7 or 3.4?
ORIGINAL: fbr
It is quite difficult to unsettle a 981. I've not noticed the "axle tramping" that surprised me in a 987S. This seemed to occur in low gears with high throttle input on tight ascents. I assume that the gear ratio was too low to cope with the torque. I'm not an expert so maybe someone else could explain?
FBR
PS the 987 was a manual gearbox.
I think that the lack of "feel" that most experience is simply the reduction in the "noise" level due to enhancements in the chassis/steering/precision/etc. On closer acquaintance I have come to appreciate
that the level feedback is actually enhanced.
ORIGINAL: fbr
(why hide it on the Spyder thread?).
ORIGINAL: flat6
Where all the 981 owners are is a mystery.
