996 Apple Play/Audio Upgrade from Porsche
- Thread starter andywill
Mattjevans
Mattjevans
Mattjevans
Mattjevans
Both my wife and I have iPhones. Mine is set up to use Siri and Apple CarPlay in another vehicle. Hers isn’t set up for Siri, but she uses the 996 a lot and wants to play music from her phone. If her phone is plugged into the phone slot, unless she activates Siri on it she can’t get any further. And so she has to switch the lead over to the USB slot to play her music. On my phone I can use either slot for music but obviously need to use the phone slot for CarPlay as well as music. So my point is that if you plan to keep the supplied USB/ Aux/Phone box hidden, and just run a USB extension lead, you will need to decide which of the two USB style slots to use, depending on whether you use Siri, and whether anyone else who uses the car wants the same set up. If the box is exposed then you can obviously change the slot to which the phone connects whenever you like and so accommodate both parties. Sorry if this sounds complicated, it’s just my wife hates Siri and she uses the car more than me! If you are the sole user then it could make a lot of sense to run just one loose cable as you suggest, and keep the box hidden.
Mattjevans
thirteeneast
Just fit a Bluetooth receiver behind the head unit.
You'll find the aux input and a 12v supply from the telephone input there.
I will cost you all of £2.50-£5
Run android auto or apple car play on your phone which is probably with you anyway and keep you car looking as it should.
Save the money to fix your Porsche perishables.
thirteeneast
thirteeneast
Mattjevans
castorman and others have given some good tips for fitting but any others would be great
starting with how to removbe the old unit !
castorman - i also have the CD unit below the old unit - you mention you bought a cubby to fit
this space - if you have details please
thanks
Mattjevans
I am trying to see if Wrighttune will fit it as I need a service and suspension work too.
Mattjevans
link is https://www.google.com/url?q=https://www.youtube.com/watch%3Fv%3D8AU_di9BzIQ&sa=U&ved=2ahUKEwjAvZ-utrTpAhX3aRUIHWHsBoMQtwIwAHoECAcQAQ&usg=AOvVaw0dKnBS4E0L_czdgwJPQcg4 It wasn’t super obvious as to how the new unit is bolted in as it doesn’t come with equivalent fixings.
