Air Con
- Thread starter Guest
edh
If the a/c isn't working, you've probably got a leak. Mine leaked from the pipework. The rubber pieces in the pipework become porous over time. The new gases appear to leak faster than the old stuff (smaller molecules I understand).
New lines from Porsche are very expensive, fitting them is a sizeable job. After trying (and failing) with 2nd hand lines (lasted 2 days), my a/c man chopped off the pipework & clamped new a/c hose to the ends. It held for a month or so, but wasn't a good fix. If I ever get round to it, I'm going to get Pirtek to replace the jubilee clips with some decent swaged fittings.
Neil Haughey
Lemon
I had to replace most of the pipework on mine, ouch!!!
Then it leaked afetr 1 week through the body of the the compressor[
Had it rebuilt that lasted about 4 weeks.
Last year Porscheshop rebuilt the compressor for me and replaced the gas with the new R12 replacement. They do not have to convert your old system to the new type and so far nearly 10 months on I have no leaks and ICE cold aircon.
It is nice but it cost me an arm and a leg to sort out[
idc1873
The old R12 is no longer in use (cfc`s etc) find someone that does "drop in`s" BUT not the R134 stuff, the equivelant to the old R12 is, if i remember correctly R431. Any air con company can do drop ins. Without use/over time the seal on the compressor can dry up and leak there, for about 40 quid its worth a go. Just had mine done and now its as cold as a very cold thing.
Fat Albert
They both know their way around the 4 pot cars
garyalanlane
The main problems with retro-fitting genuine Porsche parts are significant differences in the heater box assembly, holes/welded in drain tubes in the floor and bulkhead, and an entirely different engine bay and dashboard loom.
Not sure if the turbo engine bay loom is different to an S2, which if it is would significantly reduce the number of potential looms available that could be used.
Yep, I have looked at doing exactly that on numerous occasions... I bought a Turbo.
Chrishazle
If there is a (very much) cheaper way, I'd like to know, as aircon is something I'd love on my 968.
In all seriousness, Air Con has always struck me as a con (!) in the UK climate. Yes, it's nice for a couple of weeks of the year but the rest of the time it is extra weight to lug around and extra parts to go wrong. As well as extra fuel to be consumed when it is turned on (which you need to do regularly otherwise the system breaks, which is more money again.) Not to mention the bi-annual topping up of the thing with more gas and whatnot.
I dare say in a hotter climate it makes more sense, but in the UK I'm more than happy to simply be a bit warm ... after all, it's not like it is hot for very long 'round here.
