It's a funny thing - I'm sure you're right but you get a sort of boom from the Cayman I find. A 987.2 loaner I had once was awful on the motorway, a bit like a saloon car with a rear window only open. I think that can be fixed by adjusting the tailgate. New page etc.
- Thread starter daro911
fbr
Having done the same (testing & PEC) with the 981S Boxster & the 991S I think that applies to the 991 but not the 981. The 991 appears to be unbreakable on the PEC mini-track (note it was on winter tyres) and has definitely transformed itself into the Grandest of Tourers. The 981S is a Jekyll & Hyde car. Some of that is due, I think, to the seating position. You sit lower and more central in the 981 and you are closer to its 'pivot' point (ie less effect of pitch & jaw). The result is when 'cruising' you are distracted by the comfort. Another is the default 'economy setting' ie the misnamed "Stop/Start" button. If you switch it off (every start!) you will discover it does more than disable the stop/start and, on a PDK, the freewheel. I've found no problems with feedback from either the chassis or the steering and almost by default my daily drives are what you would consider challenging days out over challenging surfaces. PDK is excellent, once you adjust your mindset, and that's from somebody who learnt to drive on a semi-crashbox VW type 1 (and yes, a long time ago, I did 360 it on a sharp dropping turn on a wet mountain road whilst enthusiastically engaging 2nd). Comparisons with the hydraulic assist, I suspect are spurious. The main differences in the steering 'feel', I suspect, arise from the wider track, longer wheelbase and bigger wheels/tyres. On challenging roads simply oscillate between 2/3 (PDK) and you will get smiles a plenty. Open sweepy roads are happily traversed in 4/5. I rarely engage the Sport mode, it's a bit of a novelty and is far too harsh for use on the roads. To be fair I've only ever tested Spyders and the Cayman Black edition in the 987 series and not really driven them for extended periods on real roads (as opposed to tracks). Since the Spyder bit likes pictures - here's a challenging surface on my way home! Top was down, speed 55mph, air temp 4.5 degrees and raining.I've been fortunate to drive the new 981 Cayman and 991 C2S as loaners as well as both of them back to back at the PEC. Fantastic cars, but you have to push them significantly to get the same levels of smiles vs Spyder.
Given your terrain and usage, I think you have made the right choice with a 981. It looks great in red too.
You forgot to put your seats back in []
Top man 4' and the roof is down[8D] you are certainly hardy enough to have been a Spyderman too[] There is something very appealing about the 981's hard and soft top versions which was bought home to me yesterday whilst sitting at lights and crawling across the junction goes a White 991 C2 Coupe and on it's bumper a White 981 C which looked far more sportier of two IMOORIGINAL: fbr If you like a challenge try tiptoeing along the very bleak B871 on 20" summer tyres, wet roads at ~4 degrees.Coldest place in Britain (Kinbrace) when we we there on Thursday. FBR
That's better! Looks serious for sure. Don't forget to tell your insurers...
I think you would be OK with one of these fitted []ORIGINAL: flat6 Imagine rolling a Spyder. The hoops can't do much by themselves if the car rolls in a gravel trap or over an uneven surface.
Bit extreme... Painting it red.
I'm hoping to do the speed championship next year and the problem is there is not much protection in the Cayman roof, it is not that substantial. It is mandatory to wear harnesses in the Speed Championship, and that is what creates the main dilemma. If you roll with a harness on and the roof compresses your body has nowhere to go and the impact is taken on your head. (Standard seatbelt allows your body to move sideways and "submarine").ORIGINAL: MrDemon More risk rolling a car on a public high way imo. Ie curbs to hit and cars coming the other way. You see many more rolled cars in breakers yards than going to watch a track day.
It was more in response to Cecil not your car which needs a harness for racing. Stating not much fun in a Spyder rolling, which I think there is more risk on the road rolling than on a track day. Curbs to hit , ditches to fall into, cars coming the other way, if you take a look at breakers yards loads of cars are rolled.ORIGINAL: Andy FaganI'm hoping to do the speed championship next year and the problem is there is not much protection in the Cayman roof, it is not that substantial. It is mandatory to wear harnesses in the Speed Championship, and that is what creates the main dilemma. If you roll with a harness on and the roof compresses your body has nowhere to go and the impact is taken on your head. (Standard seatbelt allows your body to move sideways and "submarine").ORIGINAL: MrDemon More risk rolling a car on a public high way imo. Ie curbs to hit and cars coming the other way. You see many more rolled cars in breakers yards than going to watch a track day.
I hear you MrD. I just mean that if an activity necessitates the use of a roll cage, i'd rather have a roof as well to resist smaller intrusions. Rolling off a road down a banking, a roof could resist a fair amount of intrusion that would get past a roll cage on an open car, like small to medium branches, and for a short time, water. But single seater racing is quite safe with regards to rolling, with nothing but a roll hoop over the driver, so I won't labour the gloomy point too much[]
