- Thread starter daro911
Oops, iPhone autocorrect may need re-naming [8|] Glad you keeping an eye on the proceedings anyway!ORIGINAL: VITESSE Surely you mean an ark-
Silverstone must want to beat Wilmslow over the quiet Christmas period. No doubt one more will pop up when there's goes at the magical ~£38KORIGINAL: rob.kellock All this family talk and we've taken our eye off the ball... (I bet this link doesn't work because they never do but I'll try anyway): [link]http://ucl.porsche.de/ucl/plsql/uk/clients.show_car?sid_=36483126COJ6FXGOV1XFGD59TAN4VBE&pnr_=1&lnr_=1&caller_=[/link] Black Spyder, Porsche Silverstone, Manual, Ceramics and (?)turbo II wheels. £37850 but no bum warmers for John []
Another superb report flat6 I hope it gets into the Porsche Post as I am sure most Cayman R / Spyder owners would not have experienced the back to back drives like you just managed. Well done It's hard to pin point ride differences but it could be down to the set up on the heavier R suiting the sport chassis a little better and sometimes even down to different flavour tyres. It's a bit like the loan car or demo car always seems that much quicker than ones own example [ORIGINAL: flat6Have a good Christmas!![]()
Thanks daro911[ORIGINAL: daro911Another superb report flat6 I hope it gets into the Porsche Post as I am sure most Cayman R / Spyder owners would not have experienced the back to back drives like you just managed. Well done  It's hard to pin point ride differences but it could be down to the set up on the heavier R suiting the sport chassis a little better and sometimes even down to different flavour tyres. It's a bit like the loan car or demo car always seems that much quicker than ones own example [ORIGINAL: flat6Have a good Christmas!![]()
] Â In the past I have read journo's saying the complete opposite i.e. Spyder is slightly better than the R[&o]Â
Better handling around a track test in good old US of AORIGINAL: flat6Thanks daro911[ORIGINAL: daro911Another superb report flat6 I hope it gets into the Porsche Post as I am sure most Cayman R / Spyder owners would not have experienced the back to back drives like you just managed. Well done It's hard to pin point ride differences but it could be down to the set up on the heavier R suiting the sport chassis a little better and sometimes even down to different flavour tyres. It's a bit like the loan car or demo car always seems that much quicker than ones own example [ORIGINAL: flat6Have a good Christmas!![]()
] In the past I have read journo's saying the complete opposite i.e. Spyder is slightly better than the R[&o]
] Better in what sense?
Found it [ORIGINAL: flat6Thanks daro911[ORIGINAL: daro911In the past I have read journo's saying the complete opposite i.e. Spyder is slightly better than the R[&o]ORIGINAL: flat6Have a good Christmas!![]()
flat6 as an ex Cayman S owner and after your test drive in the "R" today I thought you might enjoy this back to back test too [ORIGINAL: flat6![]()
Here's what I said about about this over on the other thread Cecil: As you say, the R has slightly more power - albeit at higher revs - than the S/Spyder but they have identical torque figures. I'm sure that this is achieved by the R's revised (freer flowing?) exhaust manifold, which would tend to enhance the top end performance, and also by DME tweaks since the engine developers have so many tunableable functions which are controlled by the DME: 1) DFI - Fuel can be injected at dfferent times and in varying quantities throughout the power stroke; 2) Inlet valve timing and lift - +/- 20deg of crankshaft advance/retard in conjunction with low and high lift camshaft lobes; 3) Ignition timing; 4) Intake resonance manifold operation - to optimise induction airflow and boost mid-range torque. I suspect that Porsche have tweaked the first three to boost the R's power but have left the fourth option alone. Relatively small power gains are a regular feature of model year upgrades and are part of the normal development cycle. For example, Porsche have boosted the power of the 981 Cayman S by 5hp compared with the Gen II car. I run a Gen II Cayman with PASM (10mm lower than standard), LSD, Sport Chrono and 19" wheels and I'd be very interested to see how that would stack up against the Spyder and R on track with PASM in 'Sport' mode. The R wasn't available when I purchased my S and I've only driven an R briefly - but enthusiastically - at the PEC Silverstone, but on the road (where mine's used for 99% of the time) I reckon that the S probably has a better ride and handling compromise. And I wonder how many R owners were brave enough not to specify PASM, aircon and a radio to minimise weight? Whilst I admire your and Daro's choice of car, I have to say that in our climate it couldn't be my choice. One reason for choosing the Cayman over the Boxster was that I found the latter a bit claustrophobic with the hood up compared with the general spaciousness of the Cayman's interior; so I just can't imagine what it's like driving the Spyder with the "hood" on in addition to not even having the convenience of opening/closing it at the touch of a button. Although I like roadsters, I guess that I'm really a tin-top chap at heart.! Enjoy your cars in whatever fine weather we mange to get in 2013. JeffORIGINAL: flat6 Comparing the engines below, it’s only above 6000rpm that the Cayman R’s pulls away on the graphs. Therefore, you need to be approaching the red-line on the revs to access the extra power. (Both have the same peak torque at 4750 rpm but the R's peak power is at 7400rpm vs the Spyder's at 7200rpm, as per the Cayman S)![]()
Thanks daro911. That video is from the article I posted. The point I was making was not that the Spyder can't be faster (it's lower centre of gravity would show to its advantage on the tight go-kart track) but I was challenging whether the difference would be as large as 0.6s over a 30s lap. F1 cars can be closer over a longer lap. Still, the Spyder was consistently quicker over multiple laps but was just wondering if the gap was widened by a tyre issue or a changing track. I did actually think that my Spyder was quicker in a straight line but how to be sure (I didn't get to push the R in the twisties) but after 35 pages of Spyder praise[ORIGINAL: daro911Better handling around a track test in good old US of AÂ Found it [ORIGINAL: flat6Thanks daro911[ORIGINAL: daro911Â In the past I have read journo's saying the complete opposite i.e. Spyder is slightly better than the R[&o]ÂORIGINAL: flat6Have a good Christmas!![]()
]Â [link=http://www.youtube.com/watch?v=4YwG2wD69P4]http://www.youtube.com/watch?v=4YwG2wD69P4[/link]
Perfect!! Thanks. He's thinking that the reduced weight over the S is a significant contributing factor. So the extra reduced weight of the Spyder over the R (AND lower C of G) must give it the edge.ORIGINAL: daro911flat6 as an ex Cayman S owner and after your test drive in the "R" today I thought you might enjoy this back to back test too [ORIGINAL: flat6![]()
] [link=http://www.youtube.com/watch?v=5mFoSpbhAOw]http://www.youtube.com/watch?v=5mFoSpbhAOw[/link]
Thanks Jeff. My gen 1 Cayman S had PASM and as you say, it's the better option for ride comfort compromise, but in Sport mode on the road it caused oscillations that the passive Spyder/R suspension doesn't, which reserves the Sport mode solely for track. (PASM is not an option on Spyder and R but they ride better than PASM Sport mode). Oh you have LSD. I do notice some going on at the back sometime when i'm on the edge, which my non LSD Cayman didn't do. Felt as if the power was going to one side then the other and the car skips and then settles, or feels like oversteer, whereas the non LSD car would have spun up it's wheels more and i'd have to back out the throttle more. I agree that the Cayman cabin is more expansive roof up. Took a while to get used to turning around to find that the cabin ends just behind the headrest. But i'd give it up for the Spyder without a 2nd thought[ORIGINAL: MotorheadHere's what I said about about this over on the other thread Cecil: As you say, the R has slightly more power - albeit at higher revs - than the S/Spyder but they have identical torque figures. I'm sure that this is achieved by the R's revised (freer flowing?) exhaust manifold, which would tend to enhance the top end performance, and also by DME tweaks since the engine developers have so many tunableable functions which are controlled by the DME: 1) DFI - Fuel can be injected at dfferent times and in varying quantities throughout the power stroke; 2) Inlet valve timing and lift - +/- 20deg of crankshaft advance/retard in conjunction with low and high lift camshaft lobes; 3) Ignition timing; 4) Intake resonance manifold operation - to optimise induction airflow and boost mid-range torque. I suspect that Porsche have tweaked the first three to boost the R's power but have left the fourth option alone. Relatively small power gains are a regular feature of model year upgrades and are part of the normal development cycle. For example, Porsche have boosted the power of the 981 Cayman S by 5hp compared with the Gen II car. I run a Gen II Cayman with PASM (10mm lower than standard), LSD, Sport Chrono and 19" wheels and I'd be very interested to see how that would stack up against the Spyder and R on track with PASM in 'Sport' mode. The R wasn't available when I purchased my S and I've only driven an R briefly - but enthusiastically - at the PEC Silverstone, but on the road (where mine's used for 99% of the time) I reckon that the S probably has a better ride and handling compromise. And I wonder how many R owners were brave enough not to specify PASM, aircon and a radio to minimise weight? Whilst I admire your and Daro's choice of car, I have to say that in our climate it couldn't be my choice. One reason for choosing the Cayman over the Boxster was that I found the latter a bit claustrophobic with the hood up compared with the general spaciousness of the Cayman's interior; so I just can't imagine what it's like driving the Spyder with the "hood" on in addition to not even having the convenience of opening/closing it at the touch of a button. Although I like roadsters, I guess that I'm really a tin-top chap at heart.! Enjoy your cars in whatever fine weather we mange to get in 2013. JeffORIGINAL: flat6 Comparing the engines below, it’s only above 6000rpm that the Cayman R’s pulls away on the graphs. Therefore, you need to be approaching the red-line on the revs to access the extra power. (Both have the same peak torque at 4750 rpm but the R's peak power is at 7400rpm vs the Spyder's at 7200rpm, as per the Cayman S)![]()
ORIGINAL: daro911Cayman R vs GT3 tested pretty scientifically. 4-1 to the GT3 (GT3 on Cup tyres though but maybe wouldn't have changed the outcome?) http://www.caranddriver.com/features/the-mid-vs-rear-engine-debate-porsche-cayman-r-vs-911-gt3-feature?redirect=noORIGINAL: flat6 flat6 as an ex Cayman S owner and after your test drive in the "R" today I thought you might enjoy this back to back test too [] [link=http://www.youtube.com/watch?v=5mFoSpbhAOw]http://www.youtube.com/watch?v=5mFoSpbhAOw[/link]
How would you describe the difference Rob and what exactly did you prefer?ORIGINAL: rob.kellock I once spent a memorable hour at the handling circuit of the PEC Silverstone swapping between Spyder and Cayman R, manual and PDK in each. They are definitely different. I preferred the Spyder. Fortunately...
I think this guy agrees with you too Rob [ORIGINAL: rob.kellock I couldn't tell you! Spyder first (and I'd had mine 18 months or so already) and all was familiar. Jumped in the Cayman R expecting the same with a roof and it was... Different. Thought I was going mad, jumped back in a Spyder and normality returned. Back in another R and, yup, definitely not the same! Spyder felt a bit heavier and more planted somehow, the R was a bit more lively. Difficult to describe really.
