- Thread starter daro911
You'd better get cracking if you're picking the car up in the morning...[ORIGINAL: philnotts99 Rob will do! [] Plan of action will be, Paint the walls, plasterboard the ceiling and paint white, with downlights in. Then lay the eco tiles in slate grey.
DarrellWilson
May be a numpty question but....what is the definition of 'over rev'? Don' t we have a rev limiter that avoids over reving? Isn't it therefore unlikely to over rev the engine unless you did something really stupid like gearing down from 4th to 1st? There's regular references to checks on cars for rev ranges and bands, a lay mans explanation would be appreciated.ORIGINAL: jdpef356 And don't over REV[]
kenneth ritchie
I painted the breeze block walls in my last garage and they needed 3 coats to look good, breeze block is like a sponge to white paint Kenny SpiderORIGINAL: philnotts99 Thank you for the replies and pics. I see that most have normal bricks where i have breezeblock walls. Any idea if i need a different type of paint? How did you apply yours? Spray gun, brush, roller? Cheers, Phil.
You have already hit the nail on the head. Hitting the rev limiter going up is fine, that's what it's there for. Changing down the box too soon (say, on track) or fluffing 5th to 2nd instead of 5th to 4th is where it can go wrong. The computer remembers, Porsche can check and if the car has been abused then Porsche won't sell you an extended warranty. That's the layman's explanation!ORIGINAL: DarrellWilson May be a numpty question but....what is the definition of 'over rev'? Don' t we have a rev limiter that avoids over reving? Isn't it therefore unlikely to over rev the engine unless you did something really stupid like gearing down from 4th to 1st? There's regular references to checks on cars for rev ranges and bands, a lay mans explanation would be appreciated.
google money shift, not that hard to do really, but yes it is missing a gear changing down, or even changing down too early in the right gear 5th to 2nd and not 4th would be a huge error though, but when you look at it still quite easy to do in the heat of the moment. SPyder will have 6 ranges you can hit range 1 and 2 just changing up in sports mode and hitting the limiter. range 3 might be that correct downshift a tad too early Range 4 5 and 6 will be a a missed down shift into to the wrong gear. You cannot get a Porsche warranty on a car with rev in range 4 or above unless you have a scope bore test done. I think they even changed that just this year to 3 now which has caught people out buying a OPC car with rr 3 and then the OPC 2 years later saying sorry no warranty (even though they sold it with rr3) most cars will have 1 and 2 (other wise you are not driving them right and understanding the car) 3 is a tough one, Porsche see it as OK and will warranty with no checks or checks depends on when it was done, buyers like to see range 3 clear. the 981 goes to 7800 now anyway. peak power in the 987.2 is 7400 so you are going to trigger loads of rr1 if you want the BHP the car was advertised withORIGINAL: DarrellWilsonMay be a numpty question but....what is the definition of 'over rev'? Don' t we have a rev limiter that avoids over reving? Isn't it therefore unlikely to over rev the engine unless you did something really stupid like gearing down from 4th to 1st? There's regular references to checks on cars for rev ranges and bands, a lay mans explanation would be appreciated.ORIGINAL: jdpef356 And don't over REV[]
DarrellWilson
Thanks, must be a rare occurrence then, unless you really don't know how to change gear quickly. Only a potential issue with manual cars then? Assume PDK has some safety system to intervene if you try to gear down too soon?ORIGINAL: rob.kellockYou have already hit the nail on the head. Hitting the rev limiter going up is fine, that's what it's there for. Changing down the box too soon (say, on track) or fluffing 5th to 2nd instead of 5th to 4th is where it can go wrong. The computer remembers, Porsche can check and if the car has been abused then Porsche won't sell you an extended warranty. That's the layman's explanation!ORIGINAL: DarrellWilson May be a numpty question but....what is the definition of 'over rev'? Don' t we have a rev limiter that avoids over reving? Isn't it therefore unlikely to over rev the engine unless you did something really stupid like gearing down from 4th to 1st? There's regular references to checks on cars for rev ranges and bands, a lay mans explanation would be appreciated.
DarrellWilson
At what level does the limiter kick in, assume at 7700 if you believe you can hit that through changing up (we don't have sports mode in manual cars)?ORIGINAL: MrDemongoogle money shift, not that hard to do really, but yes it is missing a gear changing down, or even changing down too early in the right gear 5th to 2nd and not 4th would be a huge error though, but when you look at it still quite easy to do in the heat of the moment. SPyder will have 6 ranges you can hit range 1 and 2 just changing up in sports mode and hitting the limiter. range 3 might be that correct downshift a tad too early Range 4 5 and 6 will be a a missed down shift into to the wrong gear. You cannot get a Porsche warranty on a car with rev in range 4 or above unless you have a scope bore test done. I think they even changed that just this year to 3 now which has caught people out buying a OPC car with rr 3 and then the OPC 2 years later saying sorry no warranty (even though they sold it with rr3) most cars will have 1 and 2 (other wise you are not driving them right and understanding the car) 3 is a tough one, Porsche see it as OK and will warranty with no checks or checks depends on when it was done, buyers like to see range 3 clear. the 981 goes to 7800 now anyway. peak power in the 987.2 is 7400 so you are going to trigger loads of rr1 if you want the BHP the car was advertised withORIGINAL: DarrellWilsonMay be a numpty question but....what is the definition of 'over rev'? Don' t we have a rev limiter that avoids over reving? Isn't it therefore unlikely to over rev the engine unless you did something really stupid like gearing down from 4th to 1st? There's regular references to checks on cars for rev ranges and bands, a lay mans explanation would be appreciated.ORIGINAL: jdpef356 And don't over REV[]
Range 1: 7300-7500 U/min Range 2: 7500-7700 U/min Range 3: 7700-7900 U/min Range 4: 7900-8400 U/min Range 5: 8400-9500 U/min Range 6: 9500-11000 U/min
philnotts99
ted walker
Sold weeks ago to a friend of someone on here I believe[8D]ORIGINAL: jdpef356 Have I missed something? The white car with the all RED interior that has been for sale for yonks - has it sold? Cant seem to find a for sale anywhere.[&:]
Oh - Shame If I hadn't had mine I would have loved that colour combo!ORIGINAL: daro911Sold weeks ago to a friend of someone on here I believe[8D]ORIGINAL: jdpef356 Have I missed something? The white car with the all RED interior that has been for sale for yonks - has it sold? Cant seem to find a for sale anywhere.[&:]
DarrellWilson
I didn't realise that. What does sport mode give? How much does it cost to retro fit?ORIGINAL: MrDemon we do have sports mode in manual cars, the press cars did not have it to save weight, but I had it retro fitted, so all the modes just no stopwatch.![]()
