Nav, shiny exhaust pipes, leather steering wheel, carbon gear lever, door trims in white but centre console in leather, cruise, auto wipers, climate, rear camera, door pulls in red plus a few other bits & bobs, just over 70k. Will try to get a better interior picture tomorrow.
- Thread starter daro911
philnotts99
Sandy59 said:Nav, shiny exhaust pipes, leather steering wheel, carbon gear lever, door trims in white but centre console in leather, cruise, auto wipers, climate, rear camera, door pulls in red plus a few other bits & bobs, just over 70k. Will try to get a better interior picture tomorrow.
Be really interested to see how your interior bits look.
Phil
kitchens said:Looks lovely I think the Silver colour on the wheels suits the white better than a darker colour and a bonus you save £500
I was in 2 minds to be honest Brian but I think they do look good as you say in silver, and £500 not to be scoffed at !!
Phil, yes I'd like to see a better interior pic as well, hopefully later today, I'm abroad at the moment.
Doh![
I have just found what is standard on these cars at the Build you car
Engine 6-cylinder flat six aluminium engine, displacement: 3.8 litres, maximum power: 276 kW (375 HP), maximum torque: 420 Nm Engine features Aluminium block and cylinder heads Water-cooling with thermal management for engine and transmission VarioCam Plus camshaft control and valve lift adjustment Integrated dry-sump lubrication Electronic throttle Pressure sensor for air mass sensing Direct Fuel Injection DFI Cylinder-specific knock control Stereo Lambda control circuits Static high-voltage distribution with individual coils variable resonance intake system and engageable valves Exhaust system with centrally mounted twin tailpipe in black SPORT Chrono Package with SPORT and SPORT PLUS button Electrical system recuperation On-board diagnostics for monitoring of the emission control system Transmission 6-speed manual gearbox with dual-mass flywheel, self-adjusting clutch Porsche Torque Vectoring (PTV) incl. electronically controlled rear differential lock Rear wheel drive Chassis 20 inch Boxster Spyder light alloy wheels, Silver with 235/35 ZR 20 tryes at front, 9J x 18 with 265/35 ZR 20 tyres at rear Tyre sealing compound and electric air compressor Variable steering ratio, power-assisted (electromechanical) McPherson-strut suspension, front and rear stabilisers Porsche Stability Management (PSM) with ABS, ASR, ABD and MSR, precharging of the brake system and brake assist Sport suspension with lowering (0.78 inch) Tyre Pressure Monitoring System (TPM) Lightweight spring strut axle Dynamic transmission mounts Brakes 6-piston monobloc aluminium fixed calliper brakes front and 4-piston at rear, discs internally vented and cross-drilled, disc diameter (front/rear): 340 mm / 330 mm Pad-wear sensors on each pad Brake callipers with red paint finish Electric parking brake Body Two-seated roadster Lightweight bodyshell in steel / aluminium design Manually activating lightweight hood with electric clasp and 2 backward fins Automatically extending rear spoiler Bow-type door handles Bar in front of front end air intake in exterior colour Underbody panelling PORSCHE logotype and model designation on tailgate in black Doors and hood front and rear made of aluminium Door brakes with three rest positions Water-repellent coating on side windows Windscreen with Grey top-tint Electrical System Electric windows lifts with one-touch operation and door-seal protection Windscreen washer system with aero wiper blades, two wiper speeds, adjustable intermittent wipe and heated washer jets Electrically adjustable and heated exterior mirrors on the doors, aspherical on drivers side Universal audio interface (AUX) in the glove compartment Reading lights, interior orientation lighting and ignition-lock illumination in LED technology as well as glove compartment and luggage compartments illumination Power release buttons for front/rear luggage compartments lids Remote central locking (includes luggage compartments), electronic immobiliser (transponder system) Two 12-volt plug sockets (closed centre console storage bin, passenger footwell) CDR audio system, 7-inch colour display (touchscreen), ratio with tuner and single CD drive Lighting Bi-Xenon headlights in black, (25W) with integrated indicators and dynamic range control Smoked auxiliary LED light modules in front apron containing daytime running lights and position lights Automatic headlight activation including Welcome Home lighting Turn-signal indicators, rear lights, rear foglight and reversing light as well as third brake and licence-plate light in LED technology LED reversing light centrally integrated under rear spoiler Instruments Integrated cluster of three round instruments Instrument cluster with central rev counter and 4.6inch TFT colour display with on-board computer function, illumination white Instruments cluster with rev counter with black dials Gear indicator and lettering "Spyder" in rev counter Analogue gauges for engine speed, vehicle speed and fuel level Permanent digital displays for odometer, trip odometer, clock, external temperature and speed On-board computer Sport Chrono timer on centre console with black dial and white pointers Safety and security Full-size airbags for driver and passenger Porsche Side impact Protection System (POSIP) 3-point automatic seat belts, with buckle on seat Seat-belt pre-tensioners and force limiters Engine immbiliser with in-key transponder, central locking and remote control Two-part roll-over protection system Alarm system Air conditioning Air-conditioning system with integrated active carbon filter Steplessly adjustable fan with air recirculation and defroster functions Green tinted heat-insulating glass Interior Sport seats with split-folding backrest adjustment, manual fore/aft and height adjustment Black leather seat covering with the seat centre in Black Alcantara, headrests with stitched "Spyder" logo in black Sport steering wheel with smaller diameter and steering rim in Alcantara with manual fore/aft and height adjustment SportDesign exterior mirror Black interior with selected items in black Alcantara: Gear lever, centre strip, door panel armrests, door handles and centre console main storage compartment lid Rooflining in Black Door trims with opening loops in black Door sill guard inlays, centre console plaque and rev counter with "Spyder" logo Lockable glove compartment Storage compartment in each door Clothes hooks on seat backrests Rising centre console with switch panels, uncovered storage compartment and covered storage compartment with 12-V socket Door entry guards with model designation Vanity mirrors in both sun visors Individual cupholders (integral to dashboard trip strip) Storage net in passenger footwell Floor mats Colours Solid exterior colours: Black, Guards Red, White, Racing Yellow Standard interior colours: Black with Alcantara elements Hood colour: Black [link=http://cc.porsche.com/icc_euro/ccCall.do?rt=1447219930&screen=1280x1024&userID=EN&lang=en&PARAM=parameter_internet_en&ORDERTYPE=981511&MODELYEAR=2016&hookURL=http%3a%2f%2fwww.porsche.com%2fuk%2fmodelstart%2f] [/link]
Lots of goodies that were extras on the 987.
John if you checked what is standard on cars costing a 1/3rd of the price and then add back in what is missing from that list to your standard Spyder spec and the equation starts to move towards cars costing almost a 1/4 of the price [
Certain so called standard features today on far cheaper cars from all different manufactures now includes sat nav: mobile phone connectivity: cruise control: multi function steering wheel: DAB radio: parking sensors: add that lot back to a Porsche Spyder and the price heads further north[&:]
How Porsche pull this off in the 21st century and gets away with it is a marketing master stroke
[/quote]
The GT Silver looks very nice but not sure about the look with the Alcantara Interior red stitching and steel ring wheel looks cheap against the GTS would look nicer in full leather like the Ali trim .Wheels in SP look stunning There as so many variables on the new car unlike the older model.
[/quote]
Beats me why anyone would choose that interior with GT Silver - Spyder Classic interior looks better and is cheaper!
[/quote]
Looks very nice and shiny! White definitely makes it look like what I think a Spyder looks like (if you see what I mean!).Sandy59 said:Well mine arrived at the OPC today, haven't seen it myself yet though.
Can you tell me if this is standard White or the option onedaro911 said:Sandy59 said:Well mine arrived at the OPC today, haven't seen it myself yet though.
Looks lovely and wish you many very happy topless miles in her [8D]
LWB v.nice how long was your order delayed by or did come in close to original predicted time
'Be really interested to see how your interior bits look. Phil'
Well here's a few more pics I received today. I went leather for the centre console, wasn't that keen on the white there and thought the carbon would look out of place without the trims also in carbon, although it would obviously had gone well with the gear knob. Think I'm happy with it anyway.
philnotts99
Thank you for the extra pictures, its looking very nice!
Sandy59 said:'Be really interested to see how your interior bits look. Phil'
Looks really cool
I've gone for the leather wheel and gear lever as well, it's just a bit tight we don't get the contrast stitch on the steering wheel like they do on the GT4![]()
I tried but was turned down as "not an option" so my blue will be with red as my last 3 Boxsters all had the silver and I'm up for a splash of flash this timeflat6 said:On a blue car i'd do the same but with blue contract stitching. That would look electric!
philnotts99
So, do you get the red stitching if you go with Alcantara wheel, but if you go full leather wheel you dont get the red stitching?
Phil
Phil
