Andrew Killington said:Just hit 12.5 in East Anglia; searching for thermals
Good news... 26 degrees here in Alicante [
Bad news... The Spyders safely tucked up back in Devon [&o]
That statement just enforces the myth Boxster's are hairdressers carsMrDemon said:hair dryer to get hot.Spyder Martin said:OK so how do you take off the badges?
I've been so tempted to centralise the Spyder logo on my 987 but didn't want to b**er up the paint.
350 Miles £89990.00[jdpef356 said:That's a first for me. Mileage on application[&:]
Hi Animal - Yes I read the manual having waited so long for oneTheAnimal said:I may be wrong Daro, but I read something similar on PH and someone suggested you could have the OPC re-program one of the sockets to have continuous power.
Have you checked the manual. Have you even got a manual yet?![]()
That maybe the case today however I understand the idea of a battery conditioner is to never let the battery fall below a certain level thus eliminating the the surges when starting up that eventually lead to a cell breaking downwoodstock said:the Service engineer said it wasn't necessary as battery was larger and that the car systems shut down more quickly (6mins!) obviating the need for the trickle charge. Time will tell
CTEK works perfectly with my 2013 981, using the footwell socket. Plug it in, turn it on, lock the car. A long time ago somebody said that yes, the sockets shut down after 6 mins, but if you plug the charger in and turn it on within 6 mins of turning off the ignition it keeps the socket live. I have never tested that, but I typically have just unlocked the car before I plug in the charger, which probably has the same effect. In this respect the footwell socket works just the same as my 987.2 Cayman S did. I have two CTEKs (MXS 5.0) of slightly different vintage (the newer one has an AGM setting and the other says use the winter setting for AGM) and they both behave just the same, working their way along the sequence of lights until they eventually get to the last green one. Hope that helps.daro911 said:The overpriced Porsche Ctek Battery Conditioner doesn't work with the 981 Spyder would like to know if it works with the 981's in general
I have discovered to my cost that all the power sockets including the cigarette lighter socket shut down approximately 6 minutes after you exit the car causing the Ctek conditioner to go into loss of power mode ie fast flashing orange battery charge light
Anyone else experienced this too on a 981 [&:]
