PSH
Evening guys today has been a big day..the engine has been fired up for the first time in nearly 4 years and she's a beaut...We installed the Vitesse V-MAF+ chip and MAP sensor and then made up temporary IC and IT pipes .. cranked engine over to check oil pressure first. When happy that all was ok we tried to start the car....nothing?...which had us confused for a minute as we were sure that it would start on a flick of the key. Anyway after a little investigation with the DME relay it seemed that somehow the DME had been fitted into another relay slot t...very strange? However once this was discovered and we tried again the engine fired instantly...I had hardly touched the key when it burst into life....very satisfying to say the least, think the new heavy duty starter motor cable had a big part to play here. Tappets took about 20 secs to fill and then she purred..you will notice that idle is a little eractic and the air leaks....look closely and you'll see why... the dumpvalve isn't connected yet as we need to weld a bung into the IC pipe, same goes for the wastegate boost line to IC pipe and a few other pipes. The 60mm IC pipes themselves will lose the central hoses seen in the video as these will be welded, the IT pipework has a long way to go too as when finished the filter will be tucked away inside the wing. We moved the fuel pressure gauge from the fuel rail to the AFR which sits behind the steering fluid reservoir where it has far more room. Still lots to do, we will decide tomorrow on the final positions for the dumpvalve, wastegate banjo and other hose connections into the IC and IT pipes, these will be welded up early next week. We also need to replace the hose that connects to the idle control valve as it's only a temporary piece of hose which partially collapses under vacuum, makes the idle valve jump.....
[link]http://vid1015.photobucket.com/albums/af276/944turbo1/Porsche%20944%20Turbo/20150530_205544_zps9buwqqnn.mp4[/link] getting there folks....
Pete
