another update...anyone bored yet?....![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
First is a warning....SWEPCO 201...bad for 944 especially if fitted with a LSD, in fact having now read what this oil was actually made for rather than what is said about it on the forums i don't like it one bit. So i was experiencing some intermittent handling issues, at times the car felt like it was rolling on pebble stones when moving slowly, even in a straight line... could feel rough at speed and worse still, could swing out when taking fast sweeping bends at speed. My son had warned me that he didn't like how thick it was but I had assured him that it had good reviews from other Porsche owners?. Well we diagnosed the symptoms as a sticking diff and decided to replace the SWEPCO with a fully synthetic gear oil, I was a little horrified to see evidence of wear in the oil when it was taken out, some brass coloured which I believe may be syncro's? , there was no such signs when taking the old oil out which had been in there for a long time, thank god I wasn't happy with the way the car handled and changed the oil as it could have destroyed the diff/box. All is working well now so the diagnosis must have been correct.
The car has now done 2,500 miles on the millers engine oil so it's now well and truly bed in, I have just returned from my son's wedding in North Devon clocking up around 500 miles and she didn't miss a beat, this engine is strong, very strong and when pushed she gains speed at a very rapid rate. I can't get enough of the sound when driving through town traffic, she burbles nicely with many people unable to resist that casual look behind them to see what's coming. As i said she feels very strong, the way she pulls from idle is very addictive, pulls like a large capacity N/A car although I don't fully understand why yet. At speed she is unbelievable, a few more notches to my belt, new 911 Cab tried it on, again coming up from behind on a dual carriageway, I was doing around 80 in fourth, pulled to the inner lane and waited for the 911 to try to go past and then accelerated to match and then completely overhauled him as i moved up to 5th, he tried hard but it was a no contest situation as I pulled away at a fast rate leaving him to wonder why/how? data showed 65% throttle and 1.4 Bar of boost leaving plenty in reserve, I had just let the boost build rather than feel the need to press any harder with the throttle, the car is far too fast to do that. Other notches on the M5....BMW M3 and an AMG merc..M3 was out of his league plain and simple...Merc tried the hardest... I won't talk speeds but just to say i matched his rate of acceleration after first letting him go by so i could identify that he wasn't a plain clothes police vehicle and then let him know that he wasn't that fast with a further press of the go faster pedal. I made up the distant so quick that you would have thought that he was stationery...lol
Used a little oil on this journey( 1/4 ltr), not surprised with the speeds concerned, still loosing coolant although not sure from where...fitted new gaskets to the water housing where the water had been coming from before, I know that the heat matrix had been leaking for a number of years prior to being off the road but never by much, i suspect that this is the main reason and will investigate it when I take the dash out. It also seems that the A/C drain is blocked as I'm getting intermittent water splashes up threw the dash vents, doesn't last longer than a second or two when accelerating hard for the first time and then is gone until the car is next run, like the heater matrix i will take a look at this when the dash is removed...
Pete
Pete
