Thanks for the kind offer, Paul, but if only it were that simple. LS1 - I'm sure I don't know what you mean... [
Looking at last year's plots to check (available here if anyone wasn't aware http://www.cannell3.co.uk/944 UK League.htm) I think it's fair to say a dip in the AFR curve is not unusual on cars with the standard Motronic management. That isn't to say they all do it and on some it's much more pronounced. It is far from what you are looking for, though. My AFR is not perfect, but it's pretty good so I have attached my plot from Friday for comparison. I think you need to go custom map, probably with some hardware that has better resolution than Montronic of the 944 generation to get a straight line. In other words standalone or maybe a piggyback fuel controller.
As Tony suggested above if you are running less boost than the fuel map expects that will manifest itself in the AFR plot as richness, which is a double-whammy of less boost and less efficient combustion of what mixture you do force into the cylinders.
