Engine build progress
- Thread starter TTM
TTM
Well-known member
DivineE
I got chatting (in a pub) to one of Jaguars engineers who deals purely with mapping the engines every day. I tried to explain this fault that seems to affect all of the bigger 944t engines and he said he would be certain its all relating to the boost control not controlling the spike as it comes on boost. He reckons if you can get a boost control system in place that's good enough to keep the boost curve smooth it would go away. I got wondering about the waste gate design as it exits the crossover pipe at more than 90* from the crossover pipe. It was pointed out to be by one of the guys at Hartech and looking at the book of theory it should never be like that. You want the air flowing to the waste gate to be as close to the direction of flow into the turbo as possible so that the pressure is the same.ORIGINAL: TTM Nick, what puzzles me is that I get no knock when running lean and on the wastegate spring. When I add fuel to run lower EGTs I then get knock. I get away with the lean spike/knock when running lean and on the wastegate spring, but as soon as as I plug the piggyback to both add fuel and run a flat boost ramp (in order to get as possible to natural boost ramp of the wastegate spring) the lean spike/knock are both back. This is what I noticed yesterday evening. I have one more test to do, that is with the Piggyback with same fuel level, the same flat boost ramp and a lower peak boost pressure. If the lean spike goes away and there is no knock then the turbo probably spools too fast for the EMS to keep up.
TTM
Well-known member
That's what I was beginning to think. As detonation/preignition is caused by some unburnt fuel exploding after/before the ignition phase then perhaps if I feed the cylinders with "too much" fuel I'm likely to get "more" detonation/preignition? In that case the base fuel map works well with the ignition map even though the engine runs lean, as I don't get any knock running this way. The ignition map may not work with more fuel. The knock I am seeing when adding fuel may be preignition, not detonation. Because the system suddenly adds too much fuel when I open the throttle, and this quantity of unburnt fuel doesn't make it in the AFR logs. -> Maybe I should fit smaller injectors or upgrade the ignition?ORIGINAL: barks944 Maybe high AFR's are not causing the knock but the other way round.
TTM
Well-known member
Absolutely. The Vitesse software adjusts ignition timing in function of manifold pressure - this is what the MAP sensor is used for. Plugging or not the Piggyback doesn't seem to have any effects on how advance is handled. If ever there is an ignition map hiding in there, the end user cannot access it through the Piggyback. As there is no reason the ignition map should vary when using the Piggyback or not, I want to test if setting the EBC to the same boost charateristics (peak boost value + boost ramp) as the Wastegate spring has any impact to the lean spike/knock.ORIGINAL: barks944 Looking at the logs, the knock/lean spike happens well before the car is building boost. Just after you floor the throttle. Is this correct? If so then we can eliminate boost/boost spikes as the issue.
TTM
Well-known member
TTM
Well-known member
