Engine build progress
- Thread starter TTM
My understanding is different. You are right when you say it is heat that drives the turbo but to increase spool up you retard the timing and in doing so increase the Exhaust Gas Temperature. If you just lean out the mixture or lean it out too much as the turbo is coming on boost you risk inducing knock as spoolup is the most sensitive time for knock to occur. Generally speaking it is advancing or retarding the timing that is used to control the onset of boost via tuning. Advanced to reduce spoolup as more advance reduces EGT's and retarded to increase spoolup as this increases EGT's.ORIGINAL: sawood12 Sort of, except the pressure and flow are intrinsically linked and are not explicit so are both mutually important. A turbine extracts energy primarily from the temperature of the gas stream rather than it's speed (i.e. it is not a windmill). That is why fuel is added as the energy you are actually exploiting is the chemical energy locked up in the fuel that is liberated by burning it. The turbine is shaped so that it first throttles the area to slow the flow right down - a perfectly efficient turbo will have zero flow at its inlet (impossible to achieve of course). This increases the pressure at the turbine inlet. The turbine is then shaped so that the gas is allowed to expand through it, and as it expands it increases in flow i.e. it accelerates. It is this acceleration of the flow that generates the force that turns the turbine (force = mass x acceleration). It does this by turning the accelerating flow round a corner - so it is a bit like a garden sprinkler in this respect. So the power generated by the turbo is proportional to the pressure drop across it and the acceleration of the gas through it. To increase one you need to increase the other. So given this, to increase the spool up speed of a turbo you need to increase the pressure at its inlet (the pressure drives the expansion which drives the acceleration of the flow which drives the turbine) there are two ways to increase the pressure - increase the gas temperature i.e. lean out the AFR (for a short time) to increase temps which is the only option with a fixed geometry turbine, or to throttle the turbine more to slow the flow down and increase the inlet pressure - this is what a variable inlet turbine does (as installed on a 997 turbo) which closes up the throat area of the turbine at low rpm to maintain turbine speed.
sawood12
Yes, the mass flow rate must remain largely constant, it is the speed and pressure that varies.ORIGINAL: barks944 As the volute reduces in cross sectional area as it approaches the turbine surely the flow rate increases as you have the same mass flow but less cross section?
I think both ways work don't they? The downside to leaning out the mixture is increased risk of knock and the downside to retarding ignition is that although it increases turbo spool up you get reduced power out of the engine while it is doing it. I guess it depends on the trade off between how quickly you can spin up the turbo and/or which method is easier to achieve with regards to tuning. Maybe certain setups and engines respond better to specific methods. I've seen the AFR method used on some of the cars at the Weltmiester rolling road days.ORIGINAL: nick_968 My understanding is different. You are right when you say it is heat that drives the turbo but to increase spool up you retard the timing and in doing so increase the Exhaust Gas Temperature. If you just lean out the mixture or lean it out too much as the turbo is coming on boost you risk inducing knock as spoolup is the most sensitive time for knock to occur. Generally speaking it is advancing or retarding the timing that is used to control the onset of boost via tuning. Advanced to reduce spoolup as more advance reduces EGT's and retarded to increase spoolup as this increases EGT's.
Both ways dont work for increasing spoolup. Leaning out will increase power, but in theory prior to boost coming on you should be running at the optimum lean point anyway if tuned correctly so you shouldnt really have far to go safely. So leaning out will not improve spoolup significantly as this doesnt increase temps enough within safety margins. The other reason its the wrong way to go is because you get far better results if you richen the mixture at boost onset to maximise the charge and leave unburnt fuel to ignite in the manifold further increasing heat to drive the turbo. You can just richen the mixture, or just retard the timing, or a bit of both, only trial and error will determine the best results. This is the way all anti lag systems work albeit in a more extreme fashion with very late ignition something like 45 degrees ATDC burning hardly any fuel in the cylinder, instead most of it ignites in the manifold driving the turbo. This method is not recommended for your average turbo car though as it will kill the turbo and other components pretty fast! However all of this theory is good, but unless you have an oversized turbo and really need to punch it to get it going you just tune it as per normal as there is no point in making a turbo that is working fine work harder and producing more heat just for the sake of a hundred or so rpm. Also, advancing the timing and richening the mixture can often make the engine feel worse even though you get quicker spool compared to an engine running the optimum fuel and advance for power. In the end a good tuner will be able to balance all this out for the optimum result which will usually be somewhere in between.ORIGINAL: sawood12Yes, the mass flow rate must remain largely constant, it is the speed and pressure that varies.ORIGINAL: barks944 As the volute reduces in cross sectional area as it approaches the turbine surely the flow rate increases as you have the same mass flow but less cross section?I think both ways work don't they? The downside to leaning out the mixture is increased risk of knock and the downside to retarding ignition is that although it increases turbo spool up you get reduced power out of the engine while it is doing it. I guess it depends on the trade off between how quickly you can spin up the turbo and/or which method is easier to achieve with regards to tuning. Maybe certain setups and engines respond better to specific methods. I've seen the AFR method used on some of the cars at the Weltmiester rolling road days.ORIGINAL: nick_968 My understanding is different. You are right when you say it is heat that drives the turbo but to increase spool up you retard the timing and in doing so increase the Exhaust Gas Temperature. If you just lean out the mixture or lean it out too much as the turbo is coming on boost you risk inducing knock as spoolup is the most sensitive time for knock to occur. Generally speaking it is advancing or retarding the timing that is used to control the onset of boost via tuning. Advanced to reduce spoolup as more advance reduces EGT's and retarded to increase spoolup as this increases EGT's.
TTM
Well-known member
TTM
Well-known member
TTM
Well-known member
TTM
Well-known member
Interesting point about ducting Nick, what is your opinion on adding an additional duct in the badge panel for the standard intercooler?ORIGINAL: nick_968 Thom, one of the reasons the factory IC works so well is because it has its own dedicated ducting enabling airflow to be directly forced through the core. I am not sure but I assume the SFR unit will be standing in free air with no ducting and possibly in front of the radiator? It is very important to get proper ducting to the IC with a smaller entry point than where it meets the face of the IC for a charge air effect and to stop the air from turning around and going back out the duct. It is also important to make sure that the IC is big enough on the cross section of the core so that it provides enough airflow through the inside for the charge air and does not act as a restriction. This is a calculation based on the area of the tubes available for the air to flow through. With the SFR IC being only 8 inches high it is a little low in terms of the flow requirement for your engine at say 400hp according to the textbook. However in the real world it will probably be ok just not quite flowing as well as it could. With the speed your turbo spools up it prob wont effect spool much but it may have to work a little harder (hotter) to make the same boost as with a less restrictive core. It will be interesting to see the real world results though, be sure to log before and after intake temps at given boost levels to see if you are better of worse off with no other changes.
DivineE
Tell me about it! That's one thing I will always miss about my 3.2, it was effortlessly easy to make progress. With a big turbo 2.5 you have to adapt your driving to the car and work at it to get it to go fast, which is quite rewarding sometimes but stressful when your not in the mood! In a 3ltr 944 the car is fast no matter how you drive it. Interesting stuff on the intercooler and turbo, the two discussions are very closely linked. Nick's suggestion is spot on with what I've read, the reason stated as to why its so important to have sealed ducting and an inlet approx 30% the frontal area of the intercooler is because passing the air through the intercooler creates a restriction, the volume of air that is able to flow through that size vent is just about right to continue on through the larger area of the intercooler. If you have more, the air starts to back up, slow down and heat up forcing air round the edges and creating an area of higher pressure, slower moving air around the intercooler. I'm not sure I see the turbo theory the same way as you though Scott. Same stuff, just a different understanding that I can't get my head round. Obviously with the variable vane turbos altering the angle at low speeds to create more restriction, more pressure and thus spin the turbo faster with less flow of air makes sense. Then you reduce the angle of the blades at higher rpm when there is more airflow to reduce restriction and keep the desired level of pressure constant. What I don't understand is that everything I've read leads me to believe that its the pressure pulses of the air from the combustion that hits the blades and has the greatest effect of spinning a turbo. So its the pressure created by the restriction of the blades causing the trapped volume of air to slow and not the temperature that drives the turbo. I thought temperature was more the bi product? i.e. if you've got more temperature you must have more pressure?ORIGINAL: TTM One great thing though about the 3.0 is that it's sooooooooooo much more flexible that the 2.5. Even when boosting it at only 10psi it takes off so effortlessly on a subtle but vigorous wave of torque that I hardly ever feel the need to floor it at those speeds. I LOVE it so hard it's almost embarassing.[]
sawood12
DivineE
Thats a great idea!ORIGINAL: DivineE I have no idea how big the window for suitable intercooler through flow is on the 944 but WUF with her 924 badge panel vents was showing a fantastic temperature drop on the pre to aft temperature sensors at anything over about 40mph which is encouraging. I might take something that smokes I lot and burns slowly (like a flare maybe?) to the dyno with me when I go. Have a look with the bonnet closed and open how the air enters the vents to the intercooler when the cooling fan is at full power in front of the car. See if it flows through freely or looks like its backing up.
sawood12
I seem to remember that WUF sports a Lindsay Racing Stage 3 IC so stands to reason that you'd need more flow through the IC if it has a modified core. I guess that the air in the engine bay is extracted through the holes in the undertray? Not sure that the weedy fan put in front of the car during a rolliing road session will in anyway simulate the actual airflow when the car is in motion. One modification i'd imagined was to tilt the IC forward by 45 degrees and make some ducting (somehow) that extract the air up and out of bonnet vents. I think there is room if an IC of the size of a standard one is used and the front member is removed and replaced by something that allows better airflow through it. I think that having the air venting out of the bonnet you'll get a venturi effect and the air will actually be sucked through the IC from the airflow over the bonnet and hugely increase its flow. Similarly for the engine cooling system I'd imagined a split radiator system comprising two smaller rads mounted in the corners behind the PU and angled so the airflow comes in through the front slats, turned through 45 degrees outwards, and vents out of the side of the PU just in front of the front wheels through shark gill style vents. This is sort of similar to the Boxster arrangement. This would leave a space in the middle for power steering cooler, A/C rad and oil cooler. I'm always full of good ideas, whether or not they'd work in reality is another thing.ORIGINAL: DivineE I have no idea how big the window for suitable intercooler through flow is on the 944 but WUF with her 924 badge panel vents was showing a fantastic temperature drop on the pre to aft temperature sensors at anything over about 40mph which is encouraging. I might take something that smokes I lot and burns slowly (like a flare maybe?) to the dyno with me when I go. Have a look with the bonnet closed and open how the air enters the vents to the intercooler when the cooling fan is at full power in front of the car. See if it flows through freely or looks like its backing up.
DivineE
TTM
Well-known member
DivineE
