Engine build progress
- Thread starter TTM
TTM
Well-known member
sawood12
sawood12
Sounds good. Will watch with great interest. I still have great memories of her. I knew she was a good one. The specialist I took it to for servicing always commented on how 'tight' the car felt, and he's seen a fair few 944's in his time. I would love another 944 but fear that I would not be able to find a car as good as that one so when I do dip my toe back into Porsche ownership I think I might go for something else, or if I do go for another 944 go for something that has been majorly tinkered with e.g. 3 ltr sleeved engine or v8.ORIGINAL: barks944 Thanks for the info Scott. The engine is out of your old car btw, got the head off and pleased to report it has excellent bores. You can just catch your fingernail on the wear mark at the top of the stroke, not bad for 135K! The question is what to do now! Ive been tempted by building a 2.8 stroker, can't decide on what turbo to go with either. About the only thing Ive settled on is building my own injection system which should help keep the cost down.
TTM
Well-known member
Heres my take on it... Temperature is important for pressure and along with flow it tells you how much kinetic energy is in the gas. Flow and pressure are the result of the same type of energy except flow is directed motion and pressure is random. Volume in the crossover is constant so and increase in temp causes an increase in pressure. Both flow and pressure transfer energy to the turbo. Flow is much better than temperature for this though as the energy is directed at the turbine blades rather than randomly exerting pressure. But we have temperature and flow so we might as well make the best of both. The reason you get a pressure drop post turbo is that the flow and temperature have been reduced due to the kinetic energy being transferred to the turbine blades and that the cross section of the downpipe is greater than that of the crossover pipe thus volume has changed. Increasing the exhaust volume might not reduce the gas temperature, maybe just reduce the pressure as the volume has increased. Pressure is simply the effect of the random kinetic motion of a gas at temperature within a volume. You cant change temperature without adding or removing energy from the gas, thus simply changing volume will only change pressure not temperature.ORIGINAL: bazhart I imagined it was the flow of gas that spins up the turbo through a combination of mass flow hitting the blade angle and pressure drop accross it increasing the effect - and increasing temperature would increase pressure and through that a potential increase in volume - therefore also effectively increase the flow rate but I cannot see how temperature alone is the governing factor - but I am very willing to learn if there is another phenomenon going on. I am planning bigger exhausts to prevent back pressure restricting breathing but realise that should also reduce exhaust gas temperatures (since temperature, pressure and volume are directly or inversley mutually dependent and directly related - increase one and you increase the other - or with volume it works the other way - more volume - less pressure and temperature.
sawood12
