TTM
Last update was in February this year, so let's flog that horse again before it completely dies. My car has been running great, the 3.0 8V engine has done 25k miles so far. As the short runner inlet manifold moved the power band slightly higher in the rev range compared with the std inlet, I then installed an adjustable camshaft pulley and noticed dramatic effects on the power display by varying cam timing. I have now it adjusted to get a more or less linear thrust between 4k and 6k rpm, but I still feel the engine is not quite breathing as much as it could this is why I now have a custom camshaft on the way. In the meantime I completed the custom 6 speed gearbox project I mentioned earlier and have now the extra top gear that the engine was begging for. That means 130mph at 4k rpm, and should prove interesting on Vmax events organised at local airfields. 6th gear is actually so tall that I can't really reasonably use it on the M-way because oil temp in the sump collapses to a meager 65°C when cruising at 80mph at 2500 rpm. The 'box is just a bit taller than on an original 968 turbo S which had only 305bhp, so with about 100 more hp I expect a good ability to reach an interesting top speed, should the opportunity in safe conditions arise. Happy days [
