Engine build progress
- Thread starter TTM
TTM
I could be wrong but I think it's the car listed on the old UK 944 league tables, although these are a little dated now. Try this link http://944ukleague.wikkii.com/wiki/Porsche_944_Turbo_League_Table PeteORIGINAL: 333pg333 Mark, have you got any dyno charts of your red car in the picture above? Other engine specs?
MarkK
Thom Looking back at that thread he says he changed the cam, the intake, the turbo and the downpipe all at the same time so its hard to isolate the effect of the intake, unless I am reading it wrong.ORIGINAL: TTM Flipo in Belgium with his 968 turbo RS replica first made 335 hp / 500 N.m, then 375 hp / 466 Nm with the LR intake and a supposedly different camshaft, both at 1 bar of boost, commenting "Indeed torque numbers are down but now it holds that torque for much longer". As for the new turbo I took the car for a drive yesterday and was stunned to notice that the mid range shove and overall behaviour is pretty much the same as with the SPS turbo - under the same loads I'm seeing the same AFR numbers as before, without having even touched the fuel map! Maybe it spools only very slightly better as I see the boost curve slightly overshooting, but that's about it. That is a relief as I was slightly concerned with loosing the quick spooling and wide torque delivery of the SPS turbo. I suppose choosing the 0.82 A/R turbine housing over the larger 1.06 one was the right move.
Diver944
George Elliott
Diver944
They were both on standard cams. You can follow the link on the UK League to the "Turbo League Details" for detailed cars specs. http://944ukleague.wikkii.com/wiki/Turbo_League_DetailsORIGINAL: TTM Looking at the table of the UK league it remains that Rick also got 400bhp with his car, with the standard intake manifold and using a more restrictive turbine that on Mark's car. Not sure what camshafts were used on both engines though?
Hi Thom Yes I have heard of using the N/A cam to gain a little and I wouldn't expect this particular cam to effect the idle or Porsche wouldn't have used it in the first place. I guess I'd need someone who's tried say a Vitesse cam, who has before and after results on a 2.5l. Mind you that's given me an idea, I could ask John at Vitesse ( if I haven't already as I really can not remember) to see if he has any graphs, I haven't gone this route due to the info that's on the web already in this field, although my mind is always open. PeteORIGINAL: TTM I shortly tried a 9R (late 944 NA) camshaft on the 3L and did gain minor oomph above 4k rpm without it affecting idle whatsoever.
AndrewS
