Engine build progress
- Thread starter TTM
TTM
Well-known member
TTM
Well-known member
TTM
Well-known member
TTM
Well-known member
George Elliott
PSH
TTM
Well-known member
George Elliott
PSH
TTM
Well-known member
Have you replaced the cam and lifters since the new springs were fitted?ORIGINAL: TTM Just thought I would bump this thread for a little update. My engine has had a loud valve train since the beginning. It has munched several camshafts and a bag of lifters, and if odd-shaped Ti valve spring retainers were diagnosed faulty because they kept hitting the lifters and destroying them thus the cams, now with std retainers the valve train is still a bit noisy, more than it should. I preloaded valve springs as through the (relatively dubious) method described in the service manual and rechecked installed heights as I last had the camshaft housing off, which are all correct. At this point the only possible reason left I can think of is that these valve springs purchased then new from Porsche may actually be a fair bit stiffer than they should, causing that hammering lifter noise. Does that make sense?
TTM
Well-known member
