Engine build progress
- Thread starter TTM
appletonn
TTM
Well-known member
TTM
Well-known member
Diver944
TTM
Well-known member
Was your car fitted with a blow-off valve or a recirculating valve when it had the airbox and snorkel? I suppose you are now using a blow-off valve with the Vitesse MAF and cone filter?ORIGINAL: Diver944 When my car ran the standard airbox and snorkel, the vacumn before the turbo was so great as to literally suck oil out of the sump through the breather system [:'(]
Diver944
No it's always had the recirculating type as standard. It is placed after the MAF has taken its measure so it has to be recirculating or the AFR would be out. A MAP sensor can use a blow off type with no problem IIRCORIGINAL: TTM Was your car fitted with a blow-off valve or a recirculating valve when it had the airbox and snorkel? I suppose you are now using a blow-off valve with the Vitesse MAF and cone filter?
TTM
Well-known member
sawood12
Neil Haughey
George Elliott
marcoturbo
TTM
Well-known member
Diver944
Now that has the makings of a good idea for a long weekend [8D] Road Trip!ORIGINAL: 944Turbo maybe we should look for a french trackday late in the year, if a few of us come over then you will have something to aim for []
