Engine build progress
- Thread starter TTM
TTM
Well-known member
marcoturbo
TTM
Well-known member
Neil Haughey
TTM
Well-known member
TTM
Well-known member
Diver944
Very interesting news. Have I read that correctly? What you are saying is the shiny new looking downpipe (on the right in this picture) is actually from an early 220 Turbo and not a 3" downpipe as sold by the likes of Speedforce and Lindsey?ORIGINAL: TTM The downpipe (the one that looks as new) has got a single section while the other one has two.![]()
TTM
Well-known member
sawood12
Countersinking sounds like a plan as Pauly has suggested. If you havn't got enough room aroundthe hole to countersink you could thread the side of the flange that you have access difficulties (or use a helicoil) and use a bolt from the other side where you don't have access issues?ORIGINAL: TTM After we indexed the compressor cover there was still a problem with one of the lower bolt and we will certainly have to machine the engine mount in order to get enough clearance to fit the bolt - any suggestion on this? Should we machine the engine mount or run the turbo without this bolt? For what it's worth we put blue loctite on those bolts.
George Elliott
sawood12
TTM
Well-known member
