The engine is in the car!      We had the flanges of the exhaust manifolds resoldered on the outside as  the original solderings showed minor cracks, then smoothed out the inside of the pipe and wrapped the manifolds with insulating "wool".   We then blank-mounted the cross over pipe and noticed it had to put up with excessive strain between the turbine and the exhaust manifolds, so we heated it, let it stay mounted overnight and noticed the following day it had taken a better shape.   We then fitted the crankshaft rear seal, the flywheel, adjusted the clearance of the TDC and starter ring sensors on the engine, machined the clutch bellhousing in order to fit the engine with the sensor bracket on it and lowered the engine in the car.      The finish line is not far!      (on a side note my digicam is slowly giving up the ghost, I changed work and moved back near the German border after 20 years in Paris, far away from Sly's garage, so as of now I have little time to post properly detailed messages with nice and shiny pictures - but I will try to post some pictures in the coming weeks).
