Engine Decarbonising
- Thread starter graham.webb
edh
Indi9xx
edh
Veerzigzag
How do you tell if the bores are scored? By taking the head off? Or do you need a presumably pricey little camera on a wire? I'm rapidly heading towards a DIY service on mine, and would like to clean the engine up in the least intrusive way possible, and this thread is giving me some excellent advice! Thanks guys.We have seen far more engines saved by this than we have seen remain condemned, our rule of thumb is whenever the bores look ok, the bore treatment tends to recover the engine, if the bores are scored it isnt going to work
Veerzigzag
The coil would then still be trying (but failing) to produce a spark and hence producing a very high internal voltage, which doesn't do much for coil longevity. One answer is to remove the LT wire to the coil but then that might mess up the engine management system. I guess the safest answer is to connect the (removed) plugs to the HT wiring and make sure the plug bodies are grounded, but I am not sure if that is overkill and would be interested to hear what the experts do.Just pull the coil lead from the centre of the dizzy cap, no sparks then or am I missing something?
Indi9xx
Veerzigzag
George Elliott
Jon, sometimes a local Engineering College or University can help with these things, its a case of making your idea their idea, and dressing it up into a project which the Insurance Risk Assessor will look at differently. The academics will calculate all sorts of stuff that you just know is OK. And they will have a really interesting project as opposed to studying the wipers on a Prius. [would look at talking to the company about it and get them to approve my way as an alternative.
I'd be cautious about putting significant quantities of acetone in the fuel tank - you might find it degrades the fuel hoses/seals - if it was only in there for a short time it would probably be OK, but I'd want to look up what the hoses and seals are made of first... And as Jon says, leaving the water in the tank would give you a big risk of corrosion - again, not an issue if it was only in there for 30 minutes or so... IMO The mixture would probably seperate into two layers over time- a petrol layer and a water/acetone layer.ORIGINAL: zcacogp Pondering on this a little more, and particularly Simon's DIY-clean method, is there any reason why you shouldn't make up a mix of 50% fuel, 25% water and 25% acetone and pour this into the fuel tank when it's pretty much dry? Or even mix up equal parts of acetone and water and put this straight into a nearly-empty tank, on the basis that it will mix with the fuel that is already in there? Oli.
