Engine Decarbonising
- Thread starter graham.webb
That's worth knowing Ed, ta! I'll pick the original one up tomorrow and get it drilled and tapped in case this one leaks then I can just drop it in the garage for a quick drain, switch over and refill.ORIGINAL: edh I tried a similar sump plug - it leaked. I got a friend to drill and tap a thread into a 944 sump plug. the 944 plug has a conical sealing face so is quite different even if the flat plugs share the same thread size.
JamesO
Use a 968 one, it doesn't have a magnet (at least mine didn't) makes drilling it easier.ORIGINAL: EldavoThat's worth knowing Ed, ta! I'll pick the original one up tomorrow and get it drilled and tapped in case this one leaks then I can just drop it in the garage for a quick drain, switch over and refill.ORIGINAL: edh I tried a similar sump plug - it leaked. I got a friend to drill and tap a thread into a 944 sump plug. the 944 plug has a conical sealing face so is quite different even if the flat plugs share the same thread size.
TTM
Well-known member
I bought a cheap mini camera thing that connects to my laptop which allows me to have a look through plug holes. Not sure what they are called, but quite convenient to spot the tops of pistons.ORIGINAL: zcacogp I guess the next question is how often it needs to be done? Once a year sounds like a sensible interval to aim for.
morris944s2john
My thoughts as well, I have a degree in chemistry and the "science" mentioned above in the American product sounds highly dubious!!! I can't imagine any magic potions would be as good as the traditional method of removing the head and cleaning the combustion chamber, tops of pistons and manifolds. Or just use a good flush at a fraction of the price as mentioned above.ORIGINAL: edh hmmm sounds like snake oil to me.
timmyturtle
ChasR
edh
Isn't this a DFI issue with a build up in the inlet manifold & valves? DFI means no fuel washing this off. My DFI A2 has similar issues with variable length plastic manifold getting gummed up. Can't see how terraclean (coming through fuel injectors) will deal with inlet manifold problems in a DFI car.ORIGINAL: ChasR On some engines that Terraclean process seems to fix a problem. Just ask B7 Audi RS4 owners with the 4.2 V8 FSI engine. Despite the figures stating they made 414BHP they make anywhere between 320-380BHP as a result of carbon deposits forming inside the engine. Water methanol injection has been seen as one preventative measure as well as an aid to the power output. The Forte treatment does seem like a half decent idea it has to be said with the promise of such results in this thread.
ChasR
