Engine & gearbox removed yesterday for a good inspection, the gearbox removal found a non standard clutch from Sachs Race Engineering, the thrust bearing requires replacing, other than that all good,
The lower spark plug leads where heat is prevalent has took its toll and a full set is required, the seals between the varioram and the intakes on the heads are split where the retaining clips have cut into the rubber,
so much that the intake tubes are slightly out of shape, so new seals and new intake tubes are required, Question..... the heads have been ported and polished so much that the bore is around 2mm larger than the intake tubes
bolted to the head where the intake manifold of the varioram clamps to, does anybody know of an intake tube that is slightly bigger in diameter than the standard 993 rs ?
