Drool Drool. Brilliant !
Engine Out
- Thread starter RIVIERAM002
![DSC06782.jpg](http://i169.photobucket.com/albums/u236/rivieram002/DSC06782.jpg)
coming together nicely
http://www.unit11.co.uk/
Steve Brookes
Moderator
Marvellous pics [
Chris initially I wanted the scruffy looking engine brought back to life and any unknown mechanical issues rectified, there was nothing major found apart from plastic intake manifolds & sealing rubbers, spark plug leads, & the resonance flap on the varioram was previously incorrectly
assembled with an 'o' ring & spacer washer missing, with the 'o' ring seal missing, any oil inside the varioram tends to leak out over the engine, there was a small leak from the tappet cover, once the mechanical tappets were adjusted, new seals were fitted to the covers.
I would expect a small power gain given the inlet manifold sealing rings to the varioram were split and therefore not sealed, also the resonance flap could have been faulty due to a spacer washer missing, this could have prevented the open and shut operation to be compromised therefore insufficient
air entering the varioram above 5500 rpm ( this is activated to optimise intake length and induce intake charge oscillations < resonance charging > end result - increased intake air velocity & better fuel atomisation,) a good way of checking is to listen to a click when the ignition is turned on, this is the vacuum solenoid actuator moving the resonance flap inside the varioram, a procedure designed to prevent the flap from seizing up due to internal contamination build up.
[/right][/center][/size][/size][/center][/center]![914804_f520.jpg](http://i169.photobucket.com/albums/u236/rivieram002/914804_f520.jpg)
and here is the riviera blue train [
Steve Brookes
Moderator
I saw in the metal this morning when I called in to Unit 11. It really does look stunning in the metal. [8D]
I think they're just waiting for you to do a bit more engine bay and gearbox tunnel cleaning Steve, before they pop it back in [
![DSC06846.jpg](http://i169.photobucket.com/albums/u236/rivieram002/DSC06846.jpg)
![DSC06831.jpg](http://i169.photobucket.com/albums/u236/rivieram002/DSC06831.jpg)
Not more cleaning[
