Engine Out
- Thread starter RIVIERAM002
view this on your iphone melv
paul howells
Fairly sure jenvey do a cast alloy version of the plastic 3 bolt flange that could be sculptured to match your inlet ports,but would need insulating with some 5mm thick ptfe gaskets.
But then again standard is good!
paul howells
Its not a problem to buy a small sheet of 5mm or so ptfe and cut them out.I made my own,colin at 9m may even have some.
Steve Brookes
Moderator
Steve Brookes
Moderator
http://www.porscheclubgbforum.com/tm.asp?m=528644
[/quote]
Paul had some success at Jenvey, they are going to CNC manufacture the 6 individual inlet manifolds to the porsche spec, then machine the internal bore to 48mm which matches the head ports,
and the fuel injector housing so its looking good, the height of the inlet manifold will be reduced to compensate the ptft gaskets making the VR the same height, thanks for the info.
paul howells
You will also find the rubbers will fit better,and will not crush out of shape.May be get them anodised black for the original effect.
there were a few issues on the varioram such as the resonance flap actuator had a small spacer and o ring missing, and quite a few of the sealing rings were split over the inlet manifolds due to jubilee clips being overtightened, full set of spark plug leads needed,
The jenvey alloy inlet manifolds proved to be too expensive in the end ( tripled in price when they got the sample ) so got 6 new manifolds from Porsche which are bigger in diameter than standard 993, so its progressing, I have a few photos I will post for you.
Varioram back together
Solid Engine Mounts blasted and bolts & washers plated, the 2 mounting bolts are only temporary till the originals are plated, ( forgot to send originally)
fan & housing,
Engine Bay has had a good clean, and old sound proofing removed and new one on order.
