Fuel Lines
- Thread starter berg944
pauljmcnulty
I presume they know how to fit them as fast as anyone, but the time taken was the same as I was quoted for replacing with OEM.
Monkeythree
The other "biggie" is the spring plate bushes which can apparently be done with the beam dropped a bit but still attached to the car. But if you have the beam on the bench/floor, now would be a good time to do them.
Then of course, there are plenty off opportunites to discover rust in places which you have never been able to see before when the beam was in place and the beam itself surely deserves a little bit of love while it's off.
I am presently working my way through this list myself so I'm getting quite familiar with my back end (ooh, er!). On mine, the rubber torsion tube carrier mounts fell apart in my hands so I am currently converting them to a solid steel version and I'm going to fabricate steel mounts for the bananas while I'm at it.
Nearly forgot cv joints.
ORIGINAL: Monkeythree
You might as well do all the rear brake lines and the two hoses as they are similarly inaccessible behind the beam. You need to disconnect the brakes anyway to drop the beam so it makes sense to do them with the brake fluid drained down. But then by the same logic, you might as well take the calipers off while you're at it and check for plate lift and sort that if needs be. And then if you've got the calipers off, you might as well take the discs off and give the handbrake shoes a check........
Lol you sure you didn't miss anything [8|]
Thanks for the heads up, brakes are not long done but i think I should take the rear end off my old white S2, refurb it and do a swap. My blue one is my daily driver so cant afford for it to be off the road any length of time.
Stephen
Monkeythree
Having a spares car is a real luxury for a job like this. If you had your spare beam all pre-prepared, I would say you could probably swap out the OE fuel lines over a weekend. Mornings job to drop the beam, afternoons job to swap out the lines, second morning to refit the shiny new beam, second afternoon to fettle, adjust handbrake, bleed brakes etc
I dropped mine single handedly but it would definitely be easier with two people as its a heavy and unwieldy lump.
