Fuel Lines
- Thread starter berg944
timmyturtle
nick9one1
as the OP said, can anyone post the name of the connectors that join to the pump and the fuel rail?
hopefully its possible to get them in this sort of configuration ebay
the threaded ends connect to fuel pump/rail and use a rubber hose between the two.
pauljmcnulty
timmyturtle
Where did you get plastic ones from?
pauljmcnulty
It's like the fumes are seeping through the hoses. Annoyed as they weren't cheap and are quite possibly useless.
I'd go back to the supplier, ask him to look underneath and assure you they aren't faulty. Possibly suggest he lights a match if he's that convinced.
944 man
ORIGINAL: nick9one1
I read a good thread somewhere about types of fuel hose and another 944 owner that had problems with fuel lines seeping after a year. He listed fuel line specs like SAEJ30. I cant find it anywhere now though!
SAE J30 R6? This is susceptible to ethanol degradation, as far as I am aware - hence my initial post, as it happens.
Simon
Alasdair
Hilux
ORIGINAL: colin944
Tried to buy copper fuel line today. Cant get any anywhere. What does everyone else use? Also what are the proper sizes for the feed and return pipe and what size are the screw in conectors?Any info will be gratefully recieved.
8mm and 10mm readily available in copper on e-bay
Also in Kunifer
Hilux
Copper isn't usually the best choice as it is a soft metal and doesn't resist knocks like other metals. My VW Golf lines were replaced with some sort of steel alloy that resists corrosion .
Depends how exposed, normally they are run in protective indents and if they get squashed the car has had serious damage and if the contact points are isolated there are no corrosion issues but Kunifer is a bit harder. I use it all the time, its self supporting so doesnt need as many support fixings as flex pipe.
I replaced mine with braided hoses the whole length. I'm not happy about them,they smell of petrol,but there is no leaks!
Then change them! If it's the high pressure side you`ve got about 45psi going through them! Also with braided hoses you cant see any degredation (or leaks) -
nick9one1
So far I've got..
2.5 meters of 8mm kunifer - £17.85 Is this enough?
7.5 meters of 10mm kunifer - £44.90
Struggling to find DIN pipe fittings anywhere, and also a flaring kit that will 'square flare' not the SAE type
I've also heard the fitting 3/8 NPT flying bout on various threads.. is this used??
http://www.bondengineering.co.uk/welcome.htm
Alasdair
nick9one1
The OP seemed to have done quite a bit of research and found that Ebay - SAEJ30R9 is the best thing to use for modern fuels containing ethanol.
This article on hotrod.com supports the above theory, but suggests J30R9 is a budget solution, and Teflon (PTFE) hose is the best option. As does 944 man's thread.
So personally I've decided to ditch the idea of kunifer, and I'm going to go with either Teflon or R9. I think it will be easier to fit (with the addition of a few extra clips underneath). I don't have flare the ends of the rigid line, and I don't have to worry about replacing the flex hoses at either end as the whole lot will get swapped in one go!
Although.. I'm still not exactly sure what the original connector sizes are. Alasdair (who I'm sure is correct!) has suggested the end of the rigid lines are DIN (which seem extremely hard to find!). Is this the same for the fuel rail/FPR? On this photo I've marked the joints I'm referring to as 1 and 2. (I've got a feeling they are M16 x 1.5)
nick9one1
ORIGINAL: timmyturtle
I replaced mine with braided hoses the whole length. I'm not happy about them,they smell of petrol,but there is no leaks! Copper isn't usually the best choice as it is a soft metal and doesn't resist knocks like other metals. My VW Golf lines were replaced with some sort of steel alloy that resists corrosion .
could you elaborate on the diameter of hose and connectors you used?
Alasdair
