ORIGINAL: ghost
Fuel lines on the 944 are a specialist part. The fuel is at high pressure. If you don't have mechanical knowledge in this field, be careful. Fuel lines have been known to burst into flames if not repaired correctly. I recently had both of mine replaced front to back. The rear axle and fuel tank had to be dropped to fit the lines and new support brackets correctly. In my opinion, it's not a job that should be bodged.
Where is that popcorn smiley like on Rennlist? [
Who said anything about bodging it?
Fuel lines on most modern cars are under pressure. It is completely unnecessary to give up an arm and leg to have someone drop the rear axle and fit full length metal pipes. The original fuel lines are flexible hoses at both ends, including going back up to the tank. You simply need a new flexi line using adequately specced fuel pipe (like the original does) and appropriate swaged fittings to go over the axle and join the metal pipes the other side. The flexi line simply becomes a little longer than the original, and the metal line becomes a little shorter. There are also now hard but flexible plastic lines to replace the metal sections.
If you want to pay the extra in order to have it "all original" then fine, but turning it into a huge expensive job for any other reason is just another way to rip off the gullible.
Just out of interest, does anyone know what Porsche use on the current models?
