nick9one1
I'm not disputing hard lines are best. As you say I'm sure they will last longer and by keeping them you're retaining the cars originality.
Unfortunately for amateur mechanics like me, the tools are too expensive to buy for a one off job like this. Dropping the gearbox is also no mean feat!
I think SAE30R9 will also come in way under the cost, Teflon still under but the fittings are more expensive.
I still need to know the fitting sizes for both the fuel rail and pressure regulator.
Ive updated the picture below to try to illustrate it better.
1. is the FPR, I need to know the size of this to order the correct brass connector (pictured).
2. is to the injector rail, and again I need to know the size.
The Goodyear hoses are one continuous length and will run all the way under the car to the fuel filter, and tank. Again, what is the connector size on the fuel pump?
