Hilux
About to play with car again (as much as the wife will let me)
If I can get it all done then I`m up for Bedford on 24th Feb [8D]
Need to replace worn Mo30 suspension so having searched I will go on recommendation and having driven (briefly) Fens beast intend to go KW and Weltmeister front ARB. Where are the best places to get these? (I have searched the net but consider y`all may have better deals to be found)
Do I need to go V3 as I tend to be a fit and forget person and having tracked Ginettas and Westy`s the fuss re suspension set up for road vs track was a real pain.
How hard is it to reset the V3? If its major work then for the two or three track days a year is it worth it? The fronts will be simple enough but if its removing rears etc I`m not sure I can be asked anymore. I dont worry re road ride quality provided its not so hard that it unsettles the car in bends. (I`ve driven thousands of miles in rock hard kit cars [
Adjustable top mounts appeal for track. Have you any recommendations re effectiveness etc as I have searched posts re noise, wear and discussions re mount types but no one actually states that they make a noticeable difference. I would have thought they would reduce tyre temps and save tyres on track?
Also just ordered a tube bender so I will be making a bolt in half roll cage for the 944, a full cage for my sons Golf and a wrap around for my Zuky SJ offroader.
I`ll let you all know if I set the 944 on fire [8D]
