Is KW user friendly?
Fen, I really wanted to go with the whole PFC shooting match but they really dragged the chain. It looks like Big R/B's for me which I'm sure will be fine. It's just that when you are doing such a serious upgrade to the car you want to put something remotely from this century. Which of course Monoblocks aren't but they're more recent than the 2-piece Brembos. It seems like to put Mono's on requires some talent if you have '89 or later model cars with 'Radial' attachments. Where there's a will, there's a way, or so they say...
Funnily enough the Alcons are held in high regard by some of our American friends.
There should be some adapter kits available for Porshce monoblock upgrades. It's not exactly unheard of. I know you can get kits for the Boxster calipers from Porscheshop and Peter Empson has 993 calipers fitted to his Lux, though they will be the axial mount hubs rather than the radial mount hubs. By the way if you really want monoblocks and want some axial mount hubs i'll gladly trade with yours as i'm after some radial mount hubs!!
ORIGINAL: 333pg333
It's not Alcons that aren't worthy of mention in the same breath as Willwoods. Willwoods are cheap; good value is fine, but who wants to be cheap when it comes to brakes?
Scott, I haven't looked at the Boxter as a possible upgrade. Not sure what their spec's are? I'll check it out. Are you saying that theres a factory adapter kit for these to fit our cars?
Fen, I thought that's what you were saying but wasn't sure.
There was an article linked from here a while back (hilux?) that indicated monoblocs may be more about ease of manufacture than strength. I am dont think BR/BB's fit under 16" wheels, my MB's were clipping wheel weights on my 16 CS wheels and my 17"s look pretty full,
Tony
Billet callipers/mono blocks are relatively easily adapted IMO to fit any car of similar dimensioned brakes using adapter blocks.
Radial calipers are a different ball game if they are mounted on both sides, if not then a 90degree bolt adapter block cannot be that hard to engineer??
ORIGINAL: 944Turbo
Tony
Tony, I agree with you and i'm glad you said it first. The one-piece casting of the monoblocks will certainly lead to a lighter caliper therefore lower unsprung weight. Stories of BB's/BR's bowing under the stress of hard braking are poppycock in my view. In fact if anything the BB's/BR's should be stiffer than the monoblocks by virtue of the four huge steel bolts holding the two halves together. I think this can be seen in the design of the monoblocks such as the GT3 MK1/911 turbo calipers (bearing in mind they have the same piston sizes therefore the same power) in that they are physically larger than BB's/BR's in order to get the strength in there, and the fact they have had to be reinforced by a steel bolt through their centre to prevent them from bowing. I don't think the GT3mk1 caliper will fit under 17" rims despite having the same disc diameter than BB's. So monoblocks are the way to go for unsprung weight advantage, but that's it.
There is no doubt that the improvements in casting technology over time mean that monoblocks are simpler and cheaper to be manufactured over 2-piece calipers by virtue of a reduced parts count and a much simplified assembly process. But one thing for sure, the best part of the monoblock design is the fact that they don't need caliper plates, but that is a design feature that could be incorporated into 2-piece calipers and will only benefit you 15yrs down the line.
The problem with upgrading radial mount calipers on a radial mount hub is that unless the hole spacing between the hub and the caliper is bang on, like with medium black to big black conversions, then an adapter is required, and the chances are you will not have enough room or space to use adaptors. This is the difficulty Oli had with his GT3 MK2 6-pot caliper conversion which lead him to say it would be an easier conversion on axial mount calipers.
Patrick - see link below for the Porscheshop monoblock upgrade brake kits, one of which is for the M030 944 turbo's. I don't think the Boxster calipers are as large as BB's/BR's/GT3mk1/911turbo calipers but you may be able to source the necessary adaptors to suit your needs.
http://www.porscheshop.co.uk/acatalog/porsche_944_performance_brake_kits.html
